what the hell is the purpose of an injector resistor box???
Old Mar 22, 2004 | 07:16 PM
2000si's Avatar
Default what the hell is the purpose of an injector resistor box???
like the title says, what is the purpose of a resistor box and how does it work?
Old Mar 22, 2004 | 07:26 PM
TeamCracka's Avatar
Default Re: what the hell is the purpose of an injector resistor box??? (2000si)
Search for threads on the AFC hack and saturated/unsaturated injectors.
Stupid thread
Old Mar 22, 2004 | 07:37 PM
BoOsTiN Dc2's Avatar
i will jump on the bandwagon too...... search
Old Mar 22, 2004 | 08:37 PM
TeamCracka's Avatar
Default Re: what the hell is the purpose of an injector resistor box??? (tRaCeBuStAbUsTeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR &raquo;</TD></TR><TR><TD CLASS="quote">i will jump on the bandwagon too...... search</TD></TR></TABLE>
Heh I've come to the conclusion that any question that anyone could possibly ask about any aspect of Honda's has allready been answered and is in the archives
Old Mar 22, 2004 | 10:29 PM
PHiZ's Avatar
I like this link, see bottom.
http://www.grapeaperacing.com/...s.cfm
-PHiZ
kpt4321's Avatar
There are two types of injectors, with different resistances. If you install the lower resistance injectors in a car that was designed for high resistance, you need to add a resistor box so that the total resistance is the same.
There is more tech behind it, but that is the basics.
Old Mar 22, 2004 | 10:32 PM
5STAR3's Avatar
Default Re: (kpt4321)
PM me if you need one
Old Mar 23, 2004 | 06:16 AM
buck02's Avatar
Default Re: (envision2teg)
pm me i have 2 for sale
Old Mar 23, 2004 | 06:24 AM
ExVtec's Avatar
depending on what you are needing...Radio Shack....8 bucks gets you 4 10watt 10ohm resistors...wire inline with the yellow/black on a Honda and you are good to go...www.homemadeturbo.com
Old Mar 23, 2004 | 06:49 AM
Joseph Davis's Avatar
Default Re: what the hell is the purpose of an injector resistor box??? (TeamCracka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamCracka &raquo;</TD></TR><TR><TD CLASS="quote">Search for threads on the AFC hack and saturated/unsaturated injectors.
Stupid thread </TD></TR></TABLE>
Actually, you don't hear enough about how a resistor box is a sleazy trick so that Honda could run the cheap saturated injector drivers with the cheap peak and hold injectors. It's one of thgose things that "works," but with how high tone **** some ppl are, I'm surprised so many people run the setup.
Old Mar 23, 2004 | 07:13 AM
PHiZ's Avatar
Default Re: what the hell is the purpose of an injector resistor box??? (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, you don't hear enough about how a resistor box is a sleazy trick so that Honda could run the cheap saturated injector drivers with the cheap peak and hold injectors. It's one of thgose things that "works," but with how high tone **** some ppl are, I'm surprised so many people run the setup.</TD></TR></TABLE>
Um, we stole it from the DSM guys Let's blame them.
-PHiZ
Old Mar 23, 2004 | 07:48 AM
kpt4321's Avatar
Keep in mind that the low resistance injectors do have a purpose; they have less coils, so the have a faster responce time for "performance applications."
Old Mar 23, 2004 | 09:01 AM
Default Re: what the hell is the purpose of an injector resistor box??? (kpt4321)
Yes, but having high Z injector drivers incapable of supporting the current flow a low Z injector draws control that low Z injector by a resistor box hack makes for anything except a "performance application."
Toss an O-scope onto a resistor box/lowZ equipped vehicle and compare the pattern to a setup running matched driver/injector combo. If you have a dual trace scope, most are, you can install a KS onto your fuel rail and also plot where the injector fires along with where the ECU tries to fire it.
Hey, since we're talking Hondas + injectors, you might find this little tidbit I picked up from an EMS tuenar interesting. Bigger injectors flow more fuel in a shorter time, which due to the stock Honda ECU injector firing calibrations has the injector firing prematurely in big injector setups. Anyone who has played with a full standalone knows what an injector advance table is, and anybody with a good imagination and understanding of cars can figure out what I'm saying. This is especially noticeable at idle/as an idle quality complaint. Injector fires, hits the back of the valve, and then the valve opens. We used to think it was solely due to the Honda ECU being programmed to not support an injector fire time of less than 1.08 ms, but... the trick is to retard the distributor mechanically while adding timing to your ignition tables so that ignition timing is still the same from the engine's point of view until idle problems smooth out.
Old Mar 23, 2004 | 09:30 AM
kpt4321's Avatar
Good information J.Davis!
Another thing that bothers me about running larger injectors on Honda ECU's is the apparent lack of dead time compensation.
Old Mar 23, 2004 | 10:00 AM
And octane maps!!!11
Uhm, go diddle a MAF meter, DSM boy
Old Mar 23, 2004 | 10:02 AM
kpt4321's Avatar
Default Re: (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Uhm, go diddle a MAF meter, DSM boy </TD></TR></TABLE>
You're just jealous because when I swap cams, my car doesn't lean out.
Old Mar 23, 2004 | 10:12 AM
I'm not big into cam swaps. What I am jealous of is the way a DSM gets an insane AWD holeshot, you know, between transmission replacements.
Old Mar 23, 2004 | 10:21 AM
Bailhatch's Avatar
haha, that was low...and true.
Old Mar 23, 2004 | 10:35 AM
kpt4321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">What I am jealous of is the way a DSM gets an insane AWD holeshot, you know, between transmission replacements.
165k miles, 60+ launches, and still going stong.
Want to race me 0-60?
This thread is wicked fun.
Old Mar 23, 2004 | 10:56 AM
ITSTOCK's Avatar
Kyle what was that you lost 3 qts of oil out of all the way down new england dragway? sorry my memoories not the greatest, especially when trying to keep up with all the dsms that break down at the track
Old Mar 23, 2004 | 11:06 AM
ITSTOCK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">
You cant be racing people when you destroyed a clutch can you now Kyle?
Old Mar 23, 2004 | 11:21 AM
ludelvr's Avatar
Default Re: (ITSTOCK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSTOCK &raquo;</TD></TR><TR><TD CLASS="quote">
haha, that happened to me too! Damn oem clutches! Unfortunately, I don't have pics!
Old Mar 23, 2004 | 01:18 PM
ITSTOCK's Avatar
Default Re: (ludelvr)
supposedly thats an act 2600, looks like junk to me. I wouldnt be putting that clutch in a 300+ hp car
Old Mar 23, 2004 | 02:21 PM
Want to race me 0-60?</TD></TR></TABLE>
Sure! Want to race me from a 30 roll after?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">This thread is wicked fun.
Yes, it is
Old Mar 23, 2004 | 05:56 PM
kpt4321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSTOCK &raquo;</TD></TR><TR><TD CLASS="quote">Kyle what was that you lost 3 qts of oil out of all the way down new england dragway? sorry my memoories not the greatest, especially when trying to keep up with all the dsms that break down at the track </TD></TR></TABLE>
Yup, that was me. That's what happens when you run 22 psi without tightening the oil filter down, and forgetting to safety wire it.
I call it my "special traction sauce."
