Romulator connector help???
Old Mar 21, 2004 | 10:10 AM
curiousgpnoy's Avatar
Default Romulator connector help???
anyone know if i can replace this peice??? a while back i broke off one of the pins on it and now it wont even work w/ my ecu. i clip it in and upload the map to the romulator but when i turn the key on the interface box is still blinking. im guessing its not getting the connection from that one pin that doesnt completely go in the socket.
i was just wondering if maybe i can get another peice and just cut this part off...i figure its jsut like the ribbons on desktops and im sure theres someway to just replace it...let me know ASAP needing to get this thing tuned before this weekend
please if anyone has done this let me know where i can find one
Old Mar 21, 2004 | 10:16 AM
TurboTegB18c's Avatar
Default Re: Romulator connector help??? (curiousgpnoy)
When u flick the key on, flick it off and on again. It usually takes me 2 flips to get it to connect. Paul
Old Mar 21, 2004 | 10:19 AM
Default Re: Romulator connector help??? (TurboTegB18c)
i tried several times...i mean i can try again..but i just think its not connecting
Old Mar 21, 2004 | 02:12 PM
TTT
Old Mar 21, 2004 | 02:48 PM
racerxadam's Avatar
if you can't find a new connector all together you may be able to get a socket for the same type of chip and push the pins out of it. then take the connector apart that is on your burner and push the broken pin(s) out and replace them. I seem to remeber the pins just being pressed in the sockets.
Old Mar 21, 2004 | 03:23 PM
Mase's Avatar
Default Re: Romulator connector help??? (racerxadam)
hey are you sure the outter socket isnt broken? mine came w/ an extra socket on the end of it, if yours is the same, all you gotta do is be very careful when taking the socket off, and replace it.
Old Mar 21, 2004 | 03:25 PM
leed's Avatar
The 28pin connector on the end of those are made up of two pices, so as to make it easy to replace when you break pins. Look closely and you'll see that you can pry the machine socket away from the rest of connector w/o disturbing the ribbon cable.
Here you go:
http://www.web-tronics.com/i628boz.html
Old Mar 21, 2004 | 04:16 PM
Default Re: Romulator connector help??? (leed)
well i dont thik u can actually use a socket to replace this peice cause somehow u have to get it to connect to the ribbon...i tried to just pull out that one pin and replace it w/ another on but some how i cant get it loose w/o tearing up the ribbon itself...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">hey are you sure the outter socket isnt broken? mine came w/ an extra socket on the end of it, if yours is the same, all you gotta do is be very careful when taking the socket off, and replace it. </TD></TR></TABLE>
mine doesnt have an extra socket...i put another socket on there to see if i can get better connection but still doesnt work...i even put a multimeter to it where the end of the ribbon where its cut and wire is kinda accessible and tried to test continuity from the broken pin and that wire and it reads continuity...but i dont konw if its to just 1 wire on the ribbon or 2
Old Mar 21, 2004 | 04:18 PM
well im gonna try to borrow a friends for tonite to try to do a little tuning...but i still want to try to get mine fixed so any input would help...thanx
Old Mar 21, 2004 | 04:52 PM
xenocron's Avatar
Why dont you try callings XTRONICS (the manufacturer) and see if they will sell you just the piece that connects to the ribbon or ask where you might buy one on your own.
Old Mar 21, 2004 | 08:22 PM
Default Re: Romulator connector help??? (xenocron)
i was thinking of sending it back for them to try to fix but its all about time issues...im kinda needing it ASAP...if not ill just send it off and just borrow a friends
Old Mar 21, 2004 | 08:56 PM
PHiZ's Avatar
If you've ever opened up the romulator, you'll see the other side is just a foppy-drive cable. Xtronics has to have replacments.
-PHiZ
Old Mar 21, 2004 | 09:05 PM
Default Re: Romulator connector help??? (PHiZ)
good info man...thanx for the input
Spec C
Engine Management and Tuning
Jun 9, 2010 08:14 PM
b20_driven
Sep 18, 2008 12:22 PM
kshgl87
Oct 20, 2007 11:50 PM
93dagsr
Aug 1, 2007 11:10 AM
mugen-man
Dec 9, 2004 11:41 PM
