Precision Sc61 and InlinePro Feed line????
Old Mar 22, 2004 | 07:24 AM
B18c1turboedEK's Avatar
Default Precision Sc61 and InlinePro Feed line????
Ok i started mounting my Precision and inlinepro manifold up and the RETURN line looks like it wont run straight down.. I have 2 45 degree Earls fittings.. Someone told me to use 1 95 angle and a 45 degree, any one have pics????
This turbo hangs alot lower than my t3/t4 did
Modified by Koticcivic4u at 1:21 PM 3/22/2004
Old Mar 22, 2004 | 08:56 AM
TurboTegB18c's Avatar
Default Re: Precision Sc61 and InlinePro Feed line???? (Koticcivic4u)
Do you mean return line? Or feed line?
Old Mar 22, 2004 | 09:55 AM
Nextelbuddy's Avatar
Default Re: Precision Sc61 and InlinePro Feed line???? (TurboTegB18c)
he means return line. his turbo is hanging down a lot lower now and it looks like the oil returnline wont have a good straight shot to the oil pan now like it did before when he had a t3/t4 with a different manifold.
the problem could be solved if he could reverse his turbo and have the compressor on the A/C side and exhaust side on the tranny side but he wants to keep his A/c so that is not a option.. any other options out there, any A/C guys have a return line they can post a pic up of?
Old Mar 22, 2004 | 11:58 AM
Default Re: Precision Sc61 and InlinePro Feed line???? (nextelbuddy)
bump... anyone.. i know there are people on here that are running a inline pro mani with a sc series turbo... now with a/c probably not but im sure someone here has a answer
Old Mar 22, 2004 | 03:33 PM
bump for east coast night crew
Old Mar 22, 2004 | 03:57 PM
Jared's Avatar
do you have any pics of the setup? mine hangs very low so i had to get creative with the fittings to get a good drain angle.
Old Mar 23, 2004 | 07:01 AM
NapTownSi's Avatar
Default Re: Precision Sc61 and InlinePro Feed line???? (Jared)
I'll take pics of mine tonight and try to post them tomorrow. Mine is an sc50 .63AR, 76trim, though. Not sure if the turbo is "that" different w.r.t. the oil return location.
-Mark
Old Mar 23, 2004 | 07:13 AM
Flamenco-T's Avatar
Default Re: Precision Sc61 and InlinePro Feed line???? (NapTownSi)
This is Inlinepro with Precision SC61 turbo. One of my customers..
Stan
Old Mar 23, 2004 | 10:42 AM
NapTownSi's Avatar
Default Re: Precision Sc61 and InlinePro Feed line???? (Flamenco-T)
Here is one I just took at lunch. Mine is similar to Stan's only I reversed the fittings (45 out of the turbo to "go around" the DP, and straight fitting into the oil pan). Don't be fooled by the picture...I was below the car taking this picture so it "appears" the return line goes "Up" first, but the line is ALL downhill from the turbo flange.
Oil Return
My JDM EJ8
Dec 30, 2008 06:57 PM
BigZeke5
Oct 16, 2008 06:20 AM
crvtkllr
Sep 21, 2006 02:57 PM
97turboteg
Apr 2, 2006 09:42 PM
GraphiteAccord
Jun 17, 2003 11:18 AM
