homemade liquid intercooler routing setup question
Old Mar 23, 2004 | 07:22 PM
Sinner's Avatar
Default homemade liquid intercooler routing setup question
I was thinking about my setup which I plan on installing tomorrow.
I was planning on the water route to go like this
resivour->pump->intercooler->heat exchange->return
I was thinking about doing this since my main goal will be to drop the temps at the track with dry ice or co2. If I went like:
resivour->pump->heat exchange->intercooler->return
wouldnt I loose some of the chill in the heat exchange?
Nick
Old Mar 23, 2004 | 07:27 PM
Nid Styles's Avatar
Default Re: homemade liquid intercooler routing setup question (Sinner)
Put the pump after the intercooler.
Like this:
resivour->intercooler->pump->heat exchange->return
Keep a barrier between the heat exchanger, and the inter cooler, and create a partial vacuum in the intercooler. That is if you plan on running it pressurized, and bleed the air.
Old Mar 23, 2004 | 07:33 PM
Sinner's Avatar
please explain. Are you saying use the pump to create a vaccum? What are the advantages? I was planing on just pushing the water through, but there isnt a reason behind it. It was just the first thing that came to mind.
Nick
Old Mar 23, 2004 | 07:41 PM
Nid Styles's Avatar
Default Re: (Sinner)
Pulling the heat from something is always more efficient, than pushing the cold onto a heat source.
Old Mar 23, 2004 | 07:43 PM
Sinner's Avatar
Default Re: (nd_styles)
great tip, thanks!
Nick
Old Mar 24, 2004 | 04:29 AM
Prelude91siT's Avatar
my setup is like this
cause my pump is mounted to the bottom of my resivour
Old Mar 24, 2004 | 05:07 AM
ykracing's Avatar
Default Re: (Prelude91siT)
well, I cant say that I understand the theory behind pulling vs. pushing....
so I wont say anything about it other than,
I have res>pump>IC>res, but this is a drag car, so I dont need a heat exchanger.
Just remember that if you want to do the pull method, your pump needs to be lower than everything else... most pumps cant pull the fluid/air to get themselves primed...
which is why I would stick with the push layout.
kings**t
Nov 15, 2008 03:53 PM
TheDancingPill
Jul 23, 2007 03:43 PM
The G2 Racer
Feb 15, 2005 05:08 PM
SCHYBRID
May 10, 2002 11:50 AM
austrian type-R
Mar 8, 2002 02:00 PM
