going to dyno but have question
Old Mar 21, 2004 | 10:53 AM
redboost10's Avatar
Default going to dyno but have question
im headed to the dyno again today, last night it was running way rich with the 550's and the fuel pressure was at 20 psi(the lowest it can go). today i got some injectors outta a 91 turbo talon. i know there like 440 or 450's. my car is a 99 si, obd2 and i have the obd1 clips on them which will fit the talon injectors. my question is will i need a resistor box, is it absolutely necessary? thanks guys
Old Mar 21, 2004 | 10:54 AM
Mad Cow's Avatar
Default Re: going to dyno but have question (tgh99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">will i need a resistor box, is it absolutely necessary? thanks guys</TD></TR></TABLE>
Yes. Yes. You're welcome.
Old Mar 21, 2004 | 10:58 AM
redboost10's Avatar
Default Re: going to dyno but have question (MadCow)
thanks madcow
Old Mar 21, 2004 | 11:03 AM
redboost10's Avatar
does anyone know what stock b16a2 injectors are, i searched but couldnt find it anywhere
Old Mar 21, 2004 | 11:05 AM
FOrSfEd's Avatar
They are 240cc
Old Mar 21, 2004 | 11:08 AM
redboost10's Avatar
Default Re: going to dyno but have question (FOrSfEd)
alright, awesome, thanks guys. ill be back later tonight
Old Mar 21, 2004 | 01:23 PM
IN VTEC's Avatar
You should have at least 2 bar of rail pressure behind the injectors at all times and not more than 4 bar at max.
Old Mar 21, 2004 | 04:48 PM
redboost10's Avatar
Default Re: going to dyno but have question (IN VTEC)
i have the aem fpr that mounts on the stock rail. it has different orifaces. what are these. it has a .1", .15", and a .2". im assuming the bigger the oriface, the more fuel pressure?
Old Mar 21, 2004 | 04:57 PM
Mad Cow's Avatar
Bigger orifice means more will flow thru, hence less pressure.
Old Mar 21, 2004 | 04:58 PM
redboost10's Avatar
alright, so i got the .1" in there right now so i guess i just need smaller injectors, thanks man
Cap'N Chronic
15
Mar 9, 2011 11:45 AM
spockeg
Oct 6, 2006 09:49 PM
Rod.
Jul 5, 2004 04:37 AM
11psiTurboSI
Jun 29, 2004 05:11 AM
Chubz
Mar 1, 2003 11:47 AM
