need oil pump for my b20 set up which to pick?
* B A N N E D *
can i use vtec pumps without getting a new timing belt? im getting confused... if it was getting a new belt cuz of the vtec head and oil pump.. or was it just oil pump? .. its a straight b20 set up...
Re: need oil pump for my b20 set up which to pick? (redturbocivic)
If your timing is old then replace it at the same time. If the said "xxxx-pr3 or p72-xxxx" then it's a vtec oil pump.
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">just get the b20 it is the same as the gsr...what i read somewhere</TD></TR></TABLE>
i heard the same thing but i heard its the same as a ITR... flow wise that is... not sure on the part number tho... can any1 clairify...i need to kno i might need extra oil pressure for my turbo set up
* B A N N E D *
Re: need oil pump for my b20 set up which to pick? (ShowTymers619)
found the part number.... heres a thing for it if any1 needs info about b20's
oil pump 15100-p72-A01 Same as GSR, and ITR
yes, it's a vtec pump. I just check with the honda dealer. For 98 crv(b20), it's a "15100-p72-Ao1".
Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si »</TD></TR><TR><TD CLASS="quote">all the replacement oil pumps for obd2 cars are the same</TD></TR></TABLE>
Yup, OBD2 GSR, B20, and ITR are all the same oil pump...
