HONDATA RELATED QUESTION
Old Mar 23, 2004 | 05:29 PM
oemDC2's Avatar
Default HONDATA RELATED QUESTION
My ecu is socketed and i was wondering if i took my hondata out (returning my car back to stock) will it be okay to drive with or will i run into problems?
Old Mar 23, 2004 | 05:38 PM
dabrown's Avatar
Default Re: HONDATA RELATED QUESTION (oemDC2)
You would still need to cut a jumper to return the ECU to it's stock form..
Old Mar 23, 2004 | 05:39 PM
oemDC2's Avatar
Default Re: HONDATA RELATED QUESTION (dabrown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabrown &raquo;</TD></TR><TR><TD CLASS="quote">You would still need to cut a jumper to return the ECU to it's stock form.. </TD></TR></TABLE>
How do i do that?
Old Mar 23, 2004 | 06:54 PM
oemDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oemDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
How do i do that?</TD></TR></TABLE>
Bump
Old Mar 24, 2004 | 05:27 PM
oemDC2's Avatar
How do i go about doing this?
Old Mar 25, 2004 | 06:17 PM
oemDC2's Avatar
Old Mar 25, 2004 | 06:29 PM
2K_TEG's Avatar
no, no, no.
Why would you have to cut something to go back to stock?
PM me and I will help you out, I need to know a few things.
Old Mar 25, 2004 | 06:40 PM
oemDC2's Avatar
Default Re: HONDATA RELATED QUESTION (2K_TEG)
pm'ed .. Thanks
Old Mar 25, 2004 | 07:40 PM
PHiZ's Avatar
Jumper J1
-PHiZ
Old Mar 25, 2004 | 07:44 PM
oemDC2's Avatar
Default Re: HONDATA RELATED QUESTION (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">Jumper J1
-PHiZ</TD></TR></TABLE>
Kyle says i will need my stock EEPROM
Old Mar 25, 2004 | 07:49 PM
sicrazed's Avatar
isnt it plug and play
Old Mar 25, 2004 | 07:52 PM
oemDC2's Avatar
Default Re: HONDATA RELATED QUESTION (sicrazed)
The actual hondata unit is, but the stock EEPROM had to be removed and the EEPROM that hondata provided were soldered in so the hondata can plug up to the ECU..
Old Mar 26, 2004 | 07:05 AM
PHiZ's Avatar
On OBD1 ecus, jumper J1 controls weather the ECU loads a program from an external EPROM, or internaly from the MPU. If J1 is not jumpered, the ECU will load it's program internally from the MPU, i.e. "stock"
-PHiZ
Old Mar 26, 2004 | 07:31 AM
Kataku2K3's Avatar
PHiZ is correct
Old Mar 26, 2004 | 11:57 AM
oemDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">On OBD1 ecus, jumper J1 controls weather the ECU loads a program from an external EPROM, or internaly from the MPU. If J1 is not jumpered, the ECU will load it's program internally from the MPU, i.e. "stock"
My ECU was prepped by Hondata, I think they had to unsolder my stock EPROM and resoldered a EPROM they provided. If the J1 was not jumpered, will the ECU be stock at that point? My ecu is OBD1..
slowaccord559
Engine Management and Tuning
11
Oct 24, 2008 05:59 PM
racingfan
Jul 7, 2006 02:43 AM
JUNcr-x
Jun 9, 2006 06:49 AM
MrHeeltoe
Aug 31, 2005 02:59 PM
NiceDc2r
May 19, 2004 07:52 PM
