Overheating?
Old Mar 23, 2004 | 02:38 PM
drvfast's Avatar
Default Overheating?
I have the precision 600hp intercooler on my eg. The problem is the intercooler sits tall, and I am not getting air to my radiator. My car is over heating. what can i do? i might have to get a fludyine, i have a relay connected already so my fan stays on while the car is on. thanks
Old Mar 23, 2004 | 02:49 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Overheating? (drvfast)
what kind do you have now?
Old Mar 23, 2004 | 02:57 PM
drvfast's Avatar
Default Re: Overheating? (HybridcivicLS-T)
stock
Old Mar 23, 2004 | 04:58 PM
nsxmatt's Avatar
The intercooler is not the problem. It flows air through it (or it should). If the addition of a intercooler causes your car to overheat, you have other issues in the cooling system that need to be checked out. Check the thermostat, coolant temp fan switch, and the flow of your radiator itself. I'm running a stock 150k mile single core VX radiator with a B16 and a front mount and have no problems at all.
Old Mar 23, 2004 | 06:08 PM
drvfast's Avatar
Default Re: Overheating? (nsxmatt)
i am pretty sure it has to do with my intercooler blocking air to my radaitor when the turbo was not on my car it never overheated. I had to get a slim fan to replace my stock fan since then its been overheating. Turbo has been on for 3 days.
Old Mar 23, 2004 | 06:16 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
IS th slim fan actually on the radiator or a space in between it?
Old Mar 24, 2004 | 03:28 AM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drvfast &raquo;</TD></TR><TR><TD CLASS="quote">i am pretty sure it has to do with my intercooler blocking air to my radaitor when the turbo was not on my car it never overheated. I had to get a slim fan to replace my stock fan since then its been overheating. Turbo has been on for 3 days.</TD></TR></TABLE>
Your missing the point. The intercooler doesn't block the air, it just restricts the flow slightly. You have another problem if the little loss of airflow is causing your car to overheat. You have the large IC which means you removed the bumper support. That means your getting more flow since the support completly blocks the flow. Think of every car running a a/c condensor in front of the radiator, do they overheat? Same concept. There are tons of people on here with intercoolers in front of their radiaitors so that is not the problem.
I'm willing to bet you may have your fan hooked up backwards though..
Old Mar 24, 2004 | 02:55 PM
drvfast's Avatar
its on the radiator
Old Mar 24, 2004 | 02:59 PM
93LSivic's Avatar
DO a search on a either PWR or C&R radiators. I remember one of the employees from C&R going into a pretty nice writeup and cooling characteristics of radiators in turbo cars where the intercooler is in front of it.
Great post! Made me decide on the purchase of the C&R.
Old Mar 24, 2004 | 03:24 PM
Turbo E's Avatar
there are tons of poeple with intercoolers that block the bumper opening completely and DONT have overheating issues (like me).
I'm also using the stock EG Rad on a B18C
I'd look elsewhere.
EDIT: wow i repeated someone
GoldieWang
May 22, 2018 01:24 AM
MidwestAutoWorks
Mar 3, 2008 02:47 PM
the.hamburglar
Mar 17, 2007 08:03 AM
eggie75
Aug 20, 2006 04:39 PM
BB6-213
Jul 18, 2004 06:23 PM
