4th gen Civics/CRXs with Inline Pro manifolds...
Old 05-05-2004, 09:44 PM
Hoosier Daddy's Avatar
Default 4th gen Civics/CRXs with Inline Pro manifolds...
Someone else must have a 4 bolt Inline Pro manifold in a 4th gen Civic/CRX. HOW on Gods green Earth did you get your intercooler to fit without it being so close to the turbo? The manifold holds the turbo so far out, and on an angle, it's way too close. I have removed my bumper support and hacked the hell out of my bumper cover, but it still sits close. I'm out of ideas.
Now I have a bumper that looks like complete ***, no support, and no solution. There must be someone else with the same issue, it's a fairly common manifold.
Any and all help would be very much appreciated.
Old 05-05-2004, 10:14 PM
714phil's Avatar
Default Re: 4th gen Civics/CRXs with Inline Pro manifolds... (Hoosier Daddy)
what size is your Turbo, what size is your intercooler.. and what do you mean by "4 bolt" inline pro manifold? what side do you have your compressor housing on?
Old 05-05-2004, 10:34 PM
Default Re: 4th gen Civics/CRXs with Inline Pro manifolds... (STD ONEpointSIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STD ONEpointSIX &raquo;</TD></TR><TR><TD CLASS="quote">what size is your Turbo, what size is your intercooler.. and what do you mean by "4 bolt" inline pro manifold? what side do you have your compressor housing on?</TD></TR></TABLE>
Compressor housing is on the driver's side. It's a t3/to4e. By 4 bolt, I mean for a 4 bolt T3 as opposed to a 5 bolt.
Here are some pics:
Old 05-05-2004, 11:12 PM
New User
SiR Kid's Avatar
From the pics, you're putting the 4 bolt manifold on a 4 bolt turbo the way it wasn't designed to work. The reason it's spaced off the block like that is to have the turbo with the compressor on the opposite side... Otherwise, a 5 bolt style manifold would fit much better than that.
Old 05-05-2004, 11:25 PM
Default Re: 4th gen Civics/CRXs with Inline Pro manifolds... (SiR Kid)
I never knew it was designed for the compressor to face the passenger's side.
I wanted the compressor to face the driver's side so that I would have more room for a filter and everything backfired.
Old 05-05-2004, 11:27 PM
Mr. Softee's Avatar
i already told you it was not supposed to be like that.
Old 05-05-2004, 11:38 PM
Better than steak
Arturbo's Avatar
Default Re: 4th gen Civics/CRXs with Inline Pro manifolds... (94goldjungsr)
Turn the turbo around..
Better than steak
Arturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy &raquo;</TD></TR><TR><TD CLASS="quote">I never knew it was designed for the compressor to face the passenger's side.
I wanted the compressor to face the driver's side so that I would have more room for a filter and everything backfired.</TD></TR></TABLE>
You can fit an air filter if you run it the other way.
Old 05-05-2004, 11:50 PM
Default Re: 4th gen Civics/CRXs with Inline Pro manifolds... (Arturbo)
Well this sucks. I already had a downpipe made, and my tuning session is next Friday
Everything should flow just as well, right?
Thanks for the help guys
Old 05-05-2004, 11:55 PM
calib17a's Avatar
Just wondering, does anyone know why do they angle the flange on thier manifolds except the T4 version? It looks like it would be easier to clear the radiator with the dp if the flange was square to the motor.
Old 05-05-2004, 11:57 PM
Default Re: 4th gen Civics/CRXs with Inline Pro manifolds... (calib17a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calib17a &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering, does anyone know why do they angle the flange on thier manifolds except the T4 version? It looks like it would be easier to clear the radiator with the dp if the flange was square to the motor.</TD></TR></TABLE>
Clear the radiator AND the intercooler I've been wondering this myself...
Old 05-06-2004, 12:02 AM
project dc2's Avatar
wish you would;ve told me that earlier it was a 4 bolt inline pro manifold ..
great .. another headache comin on .
Old 05-06-2004, 12:16 AM
Default Re: 4th gen Civics/CRXs with Inline Pro manifolds... (project dc2)
I'm pretty sure I did. I also mentioned the angle. Let me guess...the new dp is for a 5 bolt?
This isn't good, I've had tuning/dyno scheduled on the 15th for over a month now
Old 05-06-2004, 12:19 AM
Better than steak
Arturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure I did. I also mentioned the angle. let me guess...the new dp is for a 5 bolt?
This isn't good, I've had tuning/dyno scheduled on the 15th for over a mont now </TD></TR></TABLE>
count the holes and how many bolts does it have?
Old 05-06-2004, 12:26 AM
Art: project_dc2 made a dp for me, its in the mail.
Looks like dp numero dos has to be sent back =/
Sorry for the lack of quoting, I'm on my cell phone
Old 05-06-2004, 07:46 AM
its a 4 botl downpipe. you didnt tell me you're using a 4 botl inline pro manifold.
Old 05-06-2004, 08:31 AM
90civichbsi's Avatar
its positioned like that on the t3 manifolds ot allow for a/c and powersteering, when the turbo is positioned the correct way at least.
as for the T4, they assume b/c of the size of the turbo that there will be no need to a/c or powersteering
Old 05-06-2004, 08:47 AM
USDM 4G VTEC's Avatar
here is my setup
and i have the same problem
i cant seem to fit my K&N filter... pissing me off since i dont wanna get a K&N motorcycle filter
Old 05-06-2004, 12:41 PM
I flipped it...much better! Just have to shave the block a tiny bit.
Old 05-06-2004, 02:50 PM
JalopySiR's Avatar
Nick, you get all worked up over nothing sometimes... and I don't even know you that well. Drop me a line if you need anything. BTW, if you ever run more than 6psi, which you will, and you don't make alot more pwer than I did... I'm going to kill you.
Old 05-06-2004, 02:56 PM
Default Re: 4th gen Civics/CRXs with Inline Pro manifolds... (JalopySiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JalopySiR &raquo;</TD></TR><TR><TD CLASS="quote">Nick, you get all worked up over nothing sometimes... and I don't even know you that well. Drop me a line if you need anything. BTW, if you ever run more than 6psi, which you will, and you don't make alot more pwer than I did... I'm going to kill you.</TD></TR></TABLE>
LOL, that's true. I do get worked up and post stupid stuff before I get my *** in the garage and try to solve it myself
You made really nice numbers at 6psi, but i'll try
Old 05-06-2004, 03:04 PM
Br1t1shguy's Avatar
Lol, man funny stuff though, backwards turbo. Everybody will eventually be a victim of stupid mistakes like that though, so you cant knock lol
Old 05-06-2004, 03:13 PM
Default Re: 4th gen Civics/CRXs with Inline Pro manifolds... (Br1t1shguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Br1t1shguy &raquo;</TD></TR><TR><TD CLASS="quote">
Lol, man funny stuff though, backwards turbo. Everybody will eventually be a victim of stupid mistakes like that though, so you cant knock lol</TD></TR></TABLE>
It would work the other way just fine, but the IC would be about an inch away from the turbine.
Old 06-03-2004, 12:19 AM
yo wheres my downpipe? snd it back already i need it.
Old 06-06-2004, 02:06 PM
NW94RS
Guest
Posts: n/a
WHERE THE **** IS MY PS2
bucklaogotpho
11-08-2005 01:55 PM
B17aTrbo
04-12-2004 09:39 PM
92lSilude
10-20-2003 02:47 PM
Apex i ITR
02-07-2003 07:46 AM
Quick Reply: 4th gen Civics/CRXs with Inline Pro manifolds...
