Zex and turbo
Old May 9, 2004 | 05:35 PM
MooreBoost's Avatar
Default Zex and turbo
I am currently in the process of installing my turbo kit on my ZC CRX. The engine will eventually be swapped for a D series with a built bottom end, once I crack a cylinder wall the internals will be swapped to another D series and so forth. I was toying with the idea of running a small ~30 shot via a Zex kit. I found a good deal on a dry kit, however Im not sure how the DSM 450's will react to the extra fuel pressure. Any ideas? Comments?
Old May 9, 2004 | 07:16 PM
scatuli's Avatar
Default Re: Zex and turbo (tegunderpressure)
would you be adding the nitrous to spool up the turbo and or to cool the intake temps?
Old May 9, 2004 | 10:50 PM
RyanEJ8's Avatar
Default Re: Zex and turbo (scatuli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scatuli &raquo;</TD></TR><TR><TD CLASS="quote">would you be adding the nitrous to spool up the turbo and or to cool the intake temps?</TD></TR></TABLE>
That's one good reason to run nitrous and turbo.
Old May 10, 2004 | 03:57 AM
MooreBoost's Avatar
Default Re: Zex and turbo (RyanCivic2000)
Definitely to cool the intake charge, but may to help spooling also, I know the 14b will have some lag, its just a question of how much.
Any ideas on how the 450's will react to the extra pressure? Maybe wet is better? Or direct port?
Old May 13, 2004 | 06:17 PM
snakepower's Avatar
If I was doin it i'd work with a wet kit...but i sold my riice long time ago, hope this helps ya C
Old May 13, 2004 | 06:22 PM
snakepower's Avatar
weren't you gonna drop that 01 cobra engine in there? you'd pull more *** than god with a crx with a cob engine...
NIAScrew2
Jul 26, 2004 11:41 AM
93acclude
Jun 28, 2004 07:18 PM
Phaze2 Mike
Honda S2000
Jul 1, 2003 06:47 PM
BOO YEAH
Aug 4, 2002 08:47 AM
b18bturbo
Aug 19, 2001 09:48 PM
