JRSC injector sizing
Old May 5, 2004 | 08:09 PM
quik1's Avatar
Default JRSC injector sizing
I just put a Jackson Racing Supercharger on a B18a with bolt ons only. The engine doesn't ping at all, do you think that it will need bigger injectors or are the stock ones fine. TIA
Old May 5, 2004 | 11:07 PM
delsolrob's Avatar
Default Re: JRSC injector sizing (quik1)
if you are running the JRSC with the normal/factory 6lbs of boost you should be able to run it with factory injectors without any problem...the FMU will increase fuel flow as boost increases.
Old May 6, 2004 | 05:22 AM
quik1's Avatar
Default Re: JRSC injector sizing (delsolrob)
Cool thats what I thought.
Old May 8, 2004 | 04:20 AM
quik1's Avatar
Does anyone else have any other opinions.
Old May 8, 2004 | 04:49 AM
TAGURIT's Avatar
I dont know what size injectors are in the B18A enging but in my B16A2 I increased the injector size by %10. So I believe stock mine are 250 and now there at 264. Not a big diffrence and I dont have a boost gauge nor a fuel gauge (Lean/Rich) but I don't hear no pinging or knocking and it's on the stock 6lbs of boost. All I got's is this damn idle surge. I'll fix.......one of these days.
Old May 8, 2004 | 05:02 AM
HNDAPWR's Avatar
Default Re: JRSC injector sizing (TAGURIT)
Stock injectors are just fine for 6 psi. Anything above 8 psi and you will want to jump to some 440's.
Old May 8, 2004 | 07:35 AM
dutchmikkel's Avatar
same here damn idle problem, but i think its between the blower and the manifold a vacuum leak
92TEGsrSC
Jul 7, 2003 09:16 AM
B_1_8_hatch
May 6, 2003 08:02 PM
1strdtko
Nov 5, 2002 11:18 AM
SlowAutoLS
Mar 27, 2002 05:47 PM
