rods and pistons for the z6
Old May 9, 2004 | 12:20 PM
RuthlessEF-9's Avatar
Default rods and pistons for the z6
i was wondering where i could get a set of rods and pistons for my z6?
everyone seems to be offering lower compression and bigger bores. I want mine to remain stock bore and compression. i just need the peace of mind that my bottom end can handle more boost
thanks
Old May 9, 2004 | 02:53 PM
eddyboy's Avatar
Default Re: rods and pistons for the z6 (RuthlessEF-9)
Good luck trying to find shelf aftermarket d16z6 in the 9.2:1 compression. I tried looking for stock compression when buying my pistons but the most of the popular piston makers only have 9.0:1 for forced induction apps. Check my sig I have a set of 9.0:1 compression CP pistons for sale, stock 75 mm bore. I am selling them cause I need to get 75.5 mm pistons.
Old May 9, 2004 | 02:55 PM
warwagon's Avatar
can you notch a block for beefy rods without pulling it from the car, i had my pan off yesterday and was kinda looking but didnt look like it?
Old May 9, 2004 | 05:18 PM
AzCivic1.6's Avatar
i think 8.5:1 d16a6 pistons give something like 9.3:1 in a z6...i think.
Old May 9, 2004 | 08:42 PM
warwagon's Avatar
Default Re: (warwagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon &raquo;</TD></TR><TR><TD CLASS="quote">can you notch a block for beefy rods without pulling it from the car, i had my pan off yesterday and was kinda looking but didnt look like it?</TD></TR></TABLE>
Old May 9, 2004 | 09:05 PM
USDM 4G VTEC's Avatar
i have the SRP 9.0:1 forged pistons (JE) and eagle rod setup
pretty good, but i also went 0.040 over
anyways i say that shall be good enough 4 u
Old May 11, 2004 | 12:17 PM
so 9.0 is that best i can do to retain the stock compression and the stock bore of 75mm
Old May 11, 2004 | 12:49 PM
Default Re: (RuthlessEF-9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuthlessEF-9 &raquo;</TD></TR><TR><TD CLASS="quote">so 9.0 is that best i can do to retain the stock compression and the stock bore of 75mm</TD></TR></TABLE>
i beleive so JE (SRP) only has 3 pistons for the Z6 (compression wise)
the 9.0.1
the 9.2.1 Stock
the 11.5.1 (donq quote me since i cant remember , but its the high comp one)
Old May 12, 2004 | 11:27 AM
Default Re: (USDM 4G VTEC)
thank for the great info i think ill have to hit those guys up
jimmy o.
Jan 6, 2010 03:11 PM
BlkChryKord
Nov 6, 2006 11:35 AM
BLK99VTECR
Jan 19, 2005 06:40 PM
spun Vtec
Nov 2, 2004 12:15 PM
beandip
Nov 12, 2002 10:49 PM
