Thicker oil needed?
Old May 9, 2004 | 08:05 AM
PM-Performance's Avatar
Default Thicker oil needed?
I have just noticed im losing oil lately. its a newer motor.
i have a small leak in my drain line that just arose, but its not losing that much fromt here.i just see a timy drop on it once and a while. but ive been noticing that its been lower on oil. i am currently running 10w30. should i go with something thicker? just seems like when i check the oil its kinda thin? i dunno if thats causing an issue with burning it off too easy?
Any info on how to know what oil viscosity and weights to use would be helpful ..thanks
Old May 9, 2004 | 08:09 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Thicker oil needed? (itr206)
Just curious, what kind of bearing clearances are you running?
Old May 9, 2004 | 08:16 AM
Default Re: Thicker oil needed? (Arturbo)
i dunno.i never got the spec sheets on any of the clearances or anything.
does that make a diff in this case?
Old May 9, 2004 | 08:21 AM
Arturbo's Avatar
Better than steak
25 Year Member
yeah it does. I prefer to run tighter clearances to run a thinner weight oil, loose clearance run a thicker weight.
Old May 9, 2004 | 08:25 AM
****, i wish i knew. Import builders did the bottom end work.
ive only been driving it in warmer waether and i know the oil is prob blazing hot.so thats prob not helping with the lower weight oil.
im wondering if like 20w50 would be too much .when i do drive it,its usually hotttt out, and i beat on it pretty good.
Old May 9, 2004 | 04:46 PM
welli threw 20-50 in it today and the oil pressure went up. so i think the other **** was deff broken down and too thin. i didnt get on it yet though to see if i feel a diff
EG-SIXV-TEC
11
Dec 13, 2012 02:45 PM
"Ridge"Racer
Honda Civic (2006 - 2015)
Aug 8, 2007 05:22 PM
jikespingleton
Jul 30, 2006 09:36 PM
ALL MOTA
May 1, 2003 09:20 PM
