greddy turbo help
Old May 9, 2004 | 04:01 PM
cyman83's Avatar
Default greddy turbo help
hey guys, me and my friend just got done installing a greddy turbo for my 2000 si. i have a question, i dont know where to hook up the nipple on the actuator to? cause i also have a greddy type s bov, and that is hooked up to im and the fpr. also, there are 2 nipples on the greddy bov, i know the top one is the one to vacuum, but what is the bottom one for?
Old May 9, 2004 | 04:53 PM
cyman83's Avatar
Default Re: greddy turbo help (cyman83)
someone must know
Old May 9, 2004 | 05:07 PM
xrunner86x's Avatar
wastegate actuator to compressor is one way to run it. on the bov the bottom nipple either vents to atmosphere, or if you are having a problem with spiking, you can hook it to a pressure source (such as a nipple added to your charge pipe)
Old May 9, 2004 | 05:38 PM
cyman83's Avatar
Default Re: (xrunner86x)
im running the greddy kit with the 18g. i dont have a nipple on the compressor. so do u just hook it up to any vacuum source? can it be the same source as the bov? and the question to the bov, do i just leave it open then?
Old May 9, 2004 | 05:42 PM
xrunner86x's Avatar
i believe you can tee it into the brake booster, when i was doing my vacuum system i did a search for turbo vacuum in the forced induction section and found all i needed. leave the bov nipple open to start, and if you find its causing spiking hook it up to pressure later.
Old May 9, 2004 | 05:53 PM
cyman83's Avatar
check im
Old May 9, 2004 | 06:55 PM
cyman83's Avatar
Default Re: (cyman83)
anyone with pics please post
Old May 9, 2004 | 09:00 PM
cyman83's Avatar
no one else knows where i could tee my actuator at?
Old May 10, 2004 | 06:41 AM
cyman83's Avatar
bump
Old May 10, 2004 | 08:22 AM
MachAF's Avatar
You can tee it anywhere. I had it teed off the FPR.
You can use the brake booster also. I would go FPR to BOV and brake booster to the wastegate. You will need to get a different sized Tee for the brake booster because the line is a lot bigger.
I don't know what the guy above is talking about by not connecting the BOV.
Old May 10, 2004 | 08:44 AM
cyman83's Avatar
Default Re: (MachAF)
hey thanks man. where could i find that size tee at?
blinddan
Feb 19, 2006 09:33 PM
egizzle8
Sep 4, 2004 12:17 PM
bumsta217
Sep 29, 2003 04:01 PM
lsvtecvx
Jul 7, 2003 07:02 PM
