Engine knocks.. BAD!
Old May 7, 2004 | 04:20 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Engine knocks.. BAD!
Hi. I have a 2001 dodge 2500 with a cummings diesel. Ever since I've had it is knocks really bad. Does anyone know why? What can I do to stop it?
I forgot to mention Ive been boosting 18psi on stock motor. I posted this here because its turbo and alot of people here know a lot about turbo stuff.
TIA
art
Old May 7, 2004 | 04:34 AM
Forrest Gump 9's Avatar
Default Re: Engine knocks.. BAD! (Arturbo)
Crank the boost to 60 psi then you'll be alright!! If not, just swap a B18 in it!!
Old May 7, 2004 | 04:46 AM
Gravy's Avatar
Default Re: Engine knocks.. BAD! (Turbo9Nut)
check the muffler bearing. that might make the knocking go away!!
Old May 7, 2004 | 05:18 AM
BigMoose's Avatar
Ether, ether, lots of ether will make that dreaded knock go away...
Old May 7, 2004 | 05:31 AM
macrosshn's Avatar
the son and the heir
Default Re: Engine knocks.. BAD! (BigMoose)
lol, someone must be really bored. BTW I don't think a diesel is supposed to make that knocking noise, its supposed to be as quiet as a gasoline engine.
Old May 7, 2004 | 06:14 AM
MiraiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Hi. I have a 2001 dodge 2500 with a cummings diesel. Ever since I've had it is knocks really bad. Does anyone know why? What can I do to stop it?
TIA
art</TD></TR></TABLE>
ban this n00b!
Old May 7, 2004 | 06:19 AM
The Crow's Avatar
Default Re: Engine knocks.. BAD! (MiraiZ)
Your knock sensor needs to be replaced.
Old May 7, 2004 | 06:21 AM
The Crow's Avatar
You may also want to try higher octane fuel.
Old May 7, 2004 | 07:13 AM
racinskittle's Avatar
lol so true
Old May 7, 2004 | 07:17 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2001 dodge</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">it knocks really bad.</TD></TR></TABLE>
Whats the problem then??
Old May 7, 2004 | 07:39 AM
GSRgrrl's Avatar
Don't drive it...problem solved!! hahaha
Old May 7, 2004 | 07:43 AM
earl's Avatar
Default Re: Engine knocks.. BAD! (GSRgrrl)
In before the lock...they should not let nubes post in this forum.
Old May 7, 2004 | 08:35 AM
Rhman19's Avatar
Default Re: Engine knocks.. BAD! (Gravy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gravy &raquo;</TD></TR><TR><TD CLASS="quote">check the muffler bearing. that might make the knocking go away!! </TD></TR></TABLE>
Yeah that or need to change the spark plugs.
Old May 7, 2004 | 08:37 AM
HXMan's Avatar
I hope you are using premium gas. Maybe you should try racegas?
Colder plugs would help too.
Old May 7, 2004 | 08:41 AM
espanol's Avatar
lol.i hope you get her home from walmart
Old May 7, 2004 | 09:36 AM
tgreaves's Avatar
Default Re: Engine knocks.. BAD! (Rhman19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhman19 &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah that or need to change the spark plugs. </TD></TR></TABLE>
You know.. It might be the throttlebody also..
Old May 7, 2004 | 09:43 AM
BEV@GSCMotorsports's Avatar
Default Re: Engine knocks.. BAD! (tgreaves)
IT"S A F&$KING DIESEL!
Old May 7, 2004 | 09:46 AM
DLB1994's Avatar
my 2000 4d turbo diesel chevy 3500 knocks the same way but i dont know how much boost am running
whats the compression on most turbo diesel any how
Old May 7, 2004 | 10:05 AM
tgreaves's Avatar
Default Re: Engine knocks.. BAD! (CivicTurbo12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicTurbo12 &raquo;</TD></TR><TR><TD CLASS="quote">IT"S A F&$KING DIESEL! </TD></TR></TABLE>
Captian obvious has arrived..
Old May 7, 2004 | 12:50 PM
SiRkid's Avatar
not enough propane!
Old May 7, 2004 | 12:52 PM
MikeMAN's Avatar
your hearing detonation
Old May 7, 2004 | 01:28 PM
boosted_dc2's Avatar
Default Re: Engine knocks.. BAD! (MikeMAN)
you might not think this will help but it helped my uncle billy. he was low on blinker fluid and accadently poured the fluid for the blinkers in where the spark plugs go on a deisel. dont ask me why he did that, but that made it knowck real loud, and also ever since he had it he has to turn on the key and wait a few seconds before he cranks it, huh must be a lemon.
Landon
Old May 7, 2004 | 02:57 PM
Jared's Avatar
Default Re: Engine knocks.. BAD! (boosted_dc2)
post *****
Old May 7, 2004 | 03:09 PM
FredoSP's Avatar
Default Re: Engine knocks.. BAD! (Jared)
Art,
I told you that its unloading in 3rd, lengthen the injector pluse and you'll run 9's.
-Fredo
Old May 7, 2004 | 03:13 PM
Mikes01GSR's Avatar
My friend who is into diesels said it may need a valve adjustment, he said to check
out http://www.tdr1.com for diesel info. Hope that helps.
