b00sting woes!!!
Old May 8, 2004 | 02:26 PM
b00stedbyFastrax's Avatar
Default b00sting woes!!!
turbo cannot seem to go past 23 psi. i have checked everything from boost controllers, leaks in the piping, manifold, I/C and all seems good. even ran the tial 40mm wg (20psi spring) open (no signal) and it will only hit 23psi. BTW it is a T4 turbo. also checked the turbo for cracks in both housing and all is good. this has me stumped for four weekes now. i would really appreciate any insight that you guys can give.
thanks
Modified by b00stedbyFastrax at 11:44 PM 5/8/2004
Old May 9, 2004 | 06:40 AM
Rod.'s Avatar
Default Re: b00sting woes!!! (b00stedbyFastrax)
you checked the piping ...did you check the silicon couplers? Might have a small slit in one of them
Old May 9, 2004 | 07:13 AM
G
sh!t happens.
Default Re: b00sting woes!!! (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">you checked the piping ...did you check the silicon couplers? Might have a small slit in one of them </TD></TR></TABLE>
it really sounds like you have a small leak in the intercooler piping. i had one like that and i was on 6 psi low boost and 10 high boost. i put it on 10psi and it would only make 5psi. one of my clamps broke and was a small leak.
Moto_340
Aug 9, 2007 07:20 AM
00BoostedGSR
Dec 23, 2006 09:59 PM
1hotcivicSi
Mar 6, 2004 07:40 AM
fastludeh22
Aug 28, 2003 09:19 AM
nd8ch
Apr 11, 2003 12:03 AM
