Inline Pro headgaskets?
Old May 5, 2004 | 09:07 PM
done's Avatar
Default Inline Pro headgaskets?
are they worth a **** or what? im gonna be running stock internals for probadly longer then i excepted.
Is it worth it for me to get one of these head gaskets so i can run 8 psi daily??
the car is a itr.. 10.6:1 compression
also who sells them??!?!
Old May 5, 2004 | 09:19 PM
BoostedITR41's Avatar
Default Re: Inline Pro headgaskets? (Jordo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">are they worth a **** or what? im gonna be running stock internals for probadly longer then i excepted.
also who sells them??!?!</TD></TR></TABLE>
worth every penny you spend. I have one in my ITR now. as long as you have the fuel for it you can run about a bar daily on 93 octane. I have run 11 to 15psi daily for over a year with a mish mash fuel system(runnin very rich) with no problems yet(knock on wood). I have the head gasket and block gaurd from them. the 3mm Head gasket drops compression about a point. http://www.inlinepro.com
Old May 5, 2004 | 09:21 PM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: Inline Pro headgaskets? (BoostedITR41)
yeah i just got mine on and it's great, and yes it lowers the CR one point
i say go with it
Old May 5, 2004 | 09:39 PM
PeteySchrilla's Avatar
Use stock headgasket
Old May 6, 2004 | 06:00 AM
done's Avatar
Default Re: Inline Pro headgaskets? (PeteySchrilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PeteySchrilla &raquo;</TD></TR><TR><TD CLASS="quote">Use stock headgasket</TD></TR></TABLE>
any reason for this??? any thing to back what you saying up?
Old May 6, 2004 | 06:10 AM
PM-Performance's Avatar
you dont need the gasket to run 8psi. yes its nice so you can run more boost, but its not needed. i have run 11-12psi on stock bottom end , stock compression for a while, with no probs. do what you wish, but its far from needed
Old May 6, 2004 | 06:34 AM
boosted hybrid's Avatar
Default Re: Inline Pro headgaskets? (itr206)
Thicker headgaskets are not needed. Having said that it heavily depends on the condition of the stock block. Lowering the compression will allow you to increase the durability out of the stock engine by placing less thermal loading, and in turn less mechanical stress on the stock components. Even with proper tuning a stock block life at 300whp will only be 20-25,000 miles tops. The headgasket with proper tuning will allow you squeeze more miles out of the engine before the stock ringlands let loose. Its ashame that cometic stopped making their 0.076" gasket, it dropped compression by a whole point and was around 100.00 or so. The inline pro headgasket is very expensive for what it is IMO.
Old May 6, 2004 | 06:38 AM
Default Re: Inline Pro headgaskets? (boosted hybrid)
yea it is pretty pricey. Cometic does make a .43 though. not as much , but will still drop it a bit. and only $100 direct from them . Cant beat it.
Old May 6, 2004 | 06:42 AM
done's Avatar
**** it ill just run stock.
Old May 6, 2004 | 06:56 AM
macrosshn's Avatar
the son and the heir
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">**** it ill just run stock.</TD></TR></TABLE>
Good to hear. I planned on running a thicker headasket to lower my cmpression as well but if Boosted-Hybrid says I don't need one then----hell, I'll say that 100+ dollars for the rebuild.
Old May 6, 2004 | 07:01 AM
GSR-T-'s Avatar
my **** runs great on 3mm inline headgasget
Old May 6, 2004 | 07:22 AM
TurboJesse
Guest
Posts: n/a
Default Re: (GSR-T-)
I run one and it works great...but they are pricey..if i had to do it again i would prolly just stack 2 oem gaskets.
Old May 6, 2004 | 07:30 AM
m R g S r's Avatar
Default Re: (Mpir3)
Can you do that, stack one gasket on top of another?
Old May 6, 2004 | 07:31 AM
Default Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">I run one and it works great...but they are pricey..if i had to do it again i would prolly just stack 2 oem gaskets.</TD></TR></TABLE>
Two OEM gaskets stacked together=poor sealing. A friend thought he could get away with this, and it never sealed correctly. You can however reuse the inline pro gaskets, just take apart the two other plys on the OEM one and rerivet them to the thick middle part of the inline pro.
Also with thicker headgasket make sure you apply 2-3 light coats of copper seal, it makes all the difference in the world.
Old May 6, 2004 | 07:52 AM
TurboJesse
Guest
Posts: n/a
Default Re: (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">
Also with thicker headgasket make sure you apply 2-3 light coats of copper seal, it makes all the difference in the world.</TD></TR></TABLE>
It seems to work good with the vw crowd, and the few people ive talked to that did it on there honda's..I agree it is ghetto though...
ITR 05082
Aug 1, 2008 04:02 PM
motormike40
18
Apr 13, 2007 08:32 PM
89D15CRXDX
Oct 11, 2006 01:29 PM
hybrid901
Honda S2000
Aug 11, 2004 10:53 AM
Cyber ITR
Jul 17, 2001 12:51 PM
