check engine light when boosting
Old May 6, 2004 | 09:27 PM
XBoostedAccordX's Avatar
Default check engine light when boosting
I have a 94 Accord ex with the fmax kit, and for some reason within the last month when i get on the car a little and i get to about 6psi the check light goes on and the car starts running funny. it feels like it goes into a limp mode. but if i pull off to the side of the road shut the car off and turn it right back on the light goes off and the car runs normal again. but if i dont boost the car or keep it low there is no problem.does anyone know what this might be caused by? i have had this kit for about 2 years and never had this problem before. thanks for your time.
Old May 6, 2004 | 09:30 PM
Sound Streamin''s Avatar
Not exactly sure what causes it, but my brothers turbo civic did the same thing. He now runs an unlimited map sensor and it doesnt do it anymore.
Old May 6, 2004 | 10:32 PM
V-SPEC 1's Avatar
Default Re: (Sound Streamin')
if you're using hondata, it may be your boost cut limeter.
Old May 6, 2004 | 10:42 PM
fi hatch's Avatar
what are you using to trick the map sensor from reading boost?
Old May 7, 2004 | 01:02 PM
Default Re: (fi hatch)
no im not running hondata.... im using what came with the F-max kit. the 2 Bar Map Sensor. i think that answers you question.
*also i am using greddy profec - b boost controller, if that has anything to do with it.
thanks everyone for your reply
Old May 7, 2004 | 01:14 PM
G
sh!t happens.
Default Re: (XBoostedAccordX)
it sounds like u map is seeing boost.
Old May 7, 2004 | 01:23 PM
Nextelbuddy's Avatar
Default Re: (G"UNIT)
sounds liek the MAP is seeing boost. check the CEL code and tell us what it is that would help
Old May 11, 2004 | 06:32 AM
spark plugs.
Guest
Posts: n/a
Default Re: (NextelBuddy)
bumpity bump bump bump...i'm having the EXACT same problem on my 1995 teggy turbo. how do you remedy this problem?
Old May 11, 2004 | 07:51 AM
Rtype16's Avatar
Default Re: (troublecodes)
If you guys are running a stock ECU with what it sounds like is an FMU with the car. You guys need to install a missing link in the car so the computer never sees boost. If it does it goes into limp mode an the car will not run properly.
Old May 11, 2004 | 08:07 AM
spark plugs.
Guest
Posts: n/a
Default Re: (Rtype16)
okay, i've been having the same prob for about 2-3 weeks, causes backfiring like a ****. is my cat ruined?
Old May 11, 2004 | 10:41 AM
ludelvr's Avatar
If you are only experiencing it when you hit boost, chances are that your map sensor is seeing boost. Check to see (if you are using one) if your missing link or check valve setup is working correctly.
Old May 11, 2004 | 10:46 AM
SOHC_MShue's Avatar
Default Re: check engine light when boosting (XBoostedAccordX)
yea definantely sounds like your map sensor is seeing boost. Have you checked the code?
Old Aug 16, 2004 | 08:24 PM
Default Re: check engine light when boosting (SOHC_MShue)
OK, I checked the CEL and the code was for the map sensor. So I replaced the map that came with the fmax kit and I added a missing link to the stock map. Then I cleared the code and check it and and the code was gone, but it was making the car run VERY rich. It blew gas all over the hood of my supra. So I plugged up the hole of the missing link and now the engine sounds like its running a lot better. but if i get on the car i hear a loud pop almost like a backfire and the car goes back into limp mode. so i dunno what to do. Please help!
Old Aug 16, 2004 | 08:36 PM
m R g S r's Avatar
Hmm. . .maybe this is telling you to get rid of the missing link ****. . .
Old Aug 16, 2004 | 10:03 PM
Muckman's Avatar
Moderator in Chief
Brand new missing link for sale here. $50 shipped. Fits on stock MAP location for Civic, Integra, Accord, Prelude.
Or you can get the same thing from Import Parts for $70 plus shipping.
Old Aug 17, 2004 | 01:37 PM
Default Re: check engine light when boosting (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Hmm. . .maybe this is telling you to get rid of the missing link ****. . .</TD></TR></TABLE>
I removed the missing link and the same thing happen. I have no clue what else to do.
Old Aug 17, 2004 | 01:41 PM
toolowsol's Avatar
how about put a stock map in, throw the fmu in the trash, and get real engine management, so you ecu actually knows what to do when it sees boost...
Old Aug 17, 2004 | 01:47 PM
Blk2000si's Avatar
Default Re: check engine light when boosting (toolowsol)
probably just your map sensor picking up boost or actually gettin boost cut
Old Aug 17, 2004 | 01:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">how about put a stock map in, throw the fmu in the trash, and get real engine management, so you ecu actually knows what to do when it sees boost...</TD></TR></TABLE>
I'm not running a FMU should I? I was thinking about sending my ecu out to be worked on, do you think that would be my best bet? thanks everyone for your help so far
Old Aug 17, 2004 | 04:33 PM
help please
Old Aug 17, 2004 | 04:41 PM
SOHC_MShue's Avatar
If your not running an fmu then what are you even using for fuel managment! Do not boost on your car anymore until you at least get something.
Old Aug 17, 2004 | 05:36 PM
I though the Fmax kits didnt need FMU's because of the 2 extra injectors. thats just what i thought
Old Aug 17, 2004 | 06:23 PM
POWERINTEGRA's Avatar
Get ready for a blown motor go have your pistons checked and motor checked before it gets worse and have no car! Is getting ready to go soon soon soon you will see smoke coming out of everywhere, oil leaks and guess what you will need new pistons, rings, etc! You already try a missing link, and all there is to it when it comes to the chek engine. Is time to go to a profesional trust me IT HAPPENED TO ME DAMB IT other ways I woulnd't be talking ****!!! Get your motor check take the head out look at the pistons let me know what happends!!
Old Aug 17, 2004 | 06:26 PM
Default Re: check engine light when boosting (POWERINTEGRA)
Oh and YES YOU DO NEED A FMU and some kind of Hondata or something to be save don't be stupid and end up regreting not using the right parts are you sure you are only boosting 6psi?
Old Aug 17, 2004 | 06:31 PM
the check engine light comes on around 6psi but im boosting 8psi
