Boosting problem
Old May 6, 2004 | 08:07 PM
tyrone27's Avatar
Default Boosting problem
I'm getting a white cloud of smoke in back of my car when I boost it. Off boost its fine. I this this problem for two days now. I was driving home from work I and I boost it and when I look out my rear view mirror its smoke city. when I let off it the smoke goes right away. off boost the car drives fine. no oil in the coolant. My breather hose is laying on my tranny. anyone got any suggestions?
Old May 6, 2004 | 08:22 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: Boosting problem (tyrone27)
white smoke sounds like coolant
Old May 6, 2004 | 10:48 PM
bluesi00's Avatar
turbo seals??
Old May 7, 2004 | 05:12 AM
Derek14's Avatar
Default Re: (bluesi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesi00 &raquo;</TD></TR><TR><TD CLASS="quote">turbo seals??</TD></TR></TABLE> If its a water cooled turbo then possibly.
Check your head gasket, have the car running and look for bubbles in the radiator when the cap is off... also sheck your oil for signs of coolant... good luck
Old May 7, 2004 | 09:11 AM
808_civic's Avatar
you are bruning coolant some place.
White Smoke = Coolant
Black = Fuel
Blue = Oil
check around for any leaks . . . . .
Old May 7, 2004 | 09:13 AM
RyanEJ8's Avatar
Like Derek said, it's probably a blown headgasket. Does it overheat at all when it idles for awhile after driving? Any signs of coolant blowing out the overflow?
Old May 7, 2004 | 03:10 PM
tyrone27's Avatar
Default Re: Boosting problem (RyanCivic2000)
no. it never overheats. I checked the coolant and oil and it non in either. its a oil only turbo.
I did notice something today though while I was reving the motor. the turbo return flange gasket is leaking. its actually smoking a little from there. whel I rev the motor at 4-5000 RPM I can see oil trying to come out of the flange seal. I thought it was a straight flow from the return to the oil pan. oil shouldn't have time get up there.
Old May 8, 2004 | 02:41 AM
tyrone27's Avatar
bump
Old May 9, 2004 | 11:58 PM
integrx's Avatar
New User
check your spark plugs
ELSUICIDA
13
Apr 4, 2007 06:07 PM
gmboogy
Nov 29, 2006 01:44 AM
EtherEG93
Sep 17, 2005 08:18 PM
greekspeed
Sep 26, 2004 06:02 AM
turbo__D
Feb 1, 2004 04:51 PM
