Compression Ratio
Old May 6, 2004 | 03:13 AM
TrumpTiteJoker's Avatar
Default Compression Ratio
Okay, here is the setup I have planned. I'm just wondering what compression pistons I should to with to get around 9.3 cr. B18b1 non-vtec head.
Benson Sleeves 84mm
Benson balanced/micropolished crank
CP Pistons & Rings 84mm
Eagle Rods
ACL Bearings
Port Flow Port & Polish, 3 angle valve job
Ferrea .5mm oversized valves
Rocket Motorsports L21 cams
Rocket Motorsports springs & retainers
I was also wondering how much power you all think I will get out of this with a gt35e at around 22-23psi?
All Suggestions welcome.
Modified by TrumpTiteJoker at 4:33 AM 5/6/2004
Old May 6, 2004 | 06:35 AM
FwdCivicHatch's Avatar
Default Re: Compression Ratio (TrumpTiteJoker)
just get pistons for your motor, and size, and they will tell you what CR they will yeild. Or you can call them directly...
Old May 6, 2004 | 10:54 PM
Default Re: Compression Ratio (FwdCivicHatch)
When I get the headwork done, the compression ratio will go down wont it? So if I'm going for a 9.3cr or somewhere close, I will have to get like, 9.5cr pistons? Any help is appreciated.
Old May 7, 2004 | 06:15 AM
if your going to be running this as a daily driver, just get the 9.0:1 C/R it will work just fine. In the long run, you can just turn up the boost a little bit more. Especially when your going to run 22+psi
allmotorpackage
Nov 9, 2008 11:38 PM
drprince89
Oct 10, 2007 11:20 AM
.adam.
Mar 2, 2007 03:39 PM
7mile
Feb 6, 2006 09:08 PM
b18cthashit
May 17, 2003 09:22 AM
