d16 turbo question??? need help
Old May 9, 2004 | 03:32 AM
jdm.ej's Avatar
Default d16 turbo question??? need help
im going to be using a turbonetics t3/t4 turbo and want to know what would be the best piping for this setup. im considering doing 2.25 from the turbo to the int and 2.5 from the int to the tb." im think the bigger the piping the slower the pick up but better high end" or do i got it backwards???
Old May 9, 2004 | 03:38 AM
jdm.ej's Avatar
Default Re: d16 turbo question??? need help (jdm.ek)
also what size intercooler do you suggest.im think around 24/10/3 some were around there. i dont want to go to big on my setup considering i only got a sohc.
Old May 9, 2004 | 05:37 AM
blackeg's Avatar
it all depends: what are your final horsepower goals and how many psi are you planning on running to get there?
Old May 9, 2004 | 08:36 AM
Jkan2001's Avatar
I think 2.5 is a bit big for a d16 unless you're going to use a built motor and run obscene ammounts of boost. I think 2.25 all around is good or 2.25 from tb to i/c and then 2 from i/c to turbo.
Old May 10, 2004 | 09:32 PM
jdm.ej's Avatar
so i guess i just go with the 2.25 and 2". downpipe and charge line is all i need to complete my turbo. hopefully i get the stuff soon becuz i just got beat by a eg hatch crucially
Old May 10, 2004 | 09:48 PM
Mag00n's Avatar
On my b16 im using 2" from turbo to IC then 2.25-2.5 IC to TB. No complaints.
Old May 10, 2004 | 09:53 PM
jdm.ej's Avatar
Default Re: d16 turbo question??? need help (SICKSOLVTEC-T)
thanks for the replies it really helps alot. since i new at boosting.
hb_guy
Jul 9, 2007 06:21 PM
Civicman86
Mar 5, 2005 06:32 AM
95turbohatch
Mar 22, 2004 12:58 PM
stinger
Jan 13, 2003 08:24 PM
