For the unexperienced turbo guy.....
Old May 7, 2004 | 10:59 AM
patdemps's Avatar
Default For the unexperienced turbo guy.....
Well first, im not the experienced turbo guy, but i've learned a lot through my setup. Lots of people ask questions about what they need. Well I am going to list some small things that some people may want to take into consideration. Feel free to add to this by all means, Im pretty much a newb anyway to turbo, but this is my learning experience.....
1.) Be prepared for the worst. Never think your setup is going to go perfect, there is always something that could go wrong during the install, etc.
2.) Be prepared to buy a ton of bolts, I think i've spent a good 3 hours in aubuchon hardware this week and I keep having to go back to more bolts. Buy extra just incase. Also, don't forget to bring the part that has the thread to match the bolt (I bought stainless steal bolts). Seal those suckers up like no tomorrow, give it everything you have when tightening the bolts (don't go half-***). The bolts that I have had to purchase were broken ones when we installed the head, bolts for the manifold to turbo, bolts for the turbo to fuel matchup, bolts for the downpipe to turbo, bolts for nearly anything you can imagine. Just be prepared (they are cheap but they add up). Have a buddy with a car that can truck back and forth and not get pissed off.
3.) Make sure ahead of time that your parts matchup. Meaning the flange on your piping matches the Blow off Valve flange or your going to need to buy another flange or change BOV's (Im in this predicament right now). Make sure the downpipe matches and you need a FLEX PIPE. This all needs to matchup and bolt to your cat. This is where a good local shop comes in to play.
4.) Fittement issues. Be prepared to modify your fans or move them around. I couldn't squeeze my turbo by my fan and I have to move it and modify it.
5.) Need some more screws or self tappers for mounting the intercooler plus a drill and a big fella is handy. Mounting the intercooler is fun, especially since once its done its nice and pretty to look at
6.) All fluids (oil, antifreeze, etc). Be prepared with some extra oil just incase you have to drain to get the shavings from drilling a hole in the oil pan. Buy the cheapest ****, drain that and fill with the good stuff (mobil 1 synthetic 10w30 is what i used). A new filter is great too.
7.) Weld. You need someone that knows how to weld/has a welder. This comes in handy for a few things. Tapping into the oil pan is the key one. You want to weld there for the oil line. I also put JB weld ontop of the weld to guarantee it. Do it right and get a great weld so your **** don't leak. The welder also comes in handy for other parts if you need it.
8.) Now I know most didn't do this. But I got my ECU chipped (PHIZ ). This is for when I first take it out, and have to drive to the dyno. Just incase you don't have money right off to tune it this may help. Or watch your guages like a **** so nothing goes wrong right off. Obviously tuning is the key to turbo so set some money aside ahead of time for tuning. A great tuning device/tuner is huge for your setup and your reliability/power.
9.) Find a few buddies to help with the setup instead of forking out a ton of money. Not only do you learn a ton of **** but you also feel better by doing it yourself, helps when you have to repair things (because your going to have to eventually, its not going to be perfect). A few buddies that can help with everything or can do other things, or atleast provide entertainment for the time being, because the install isn't exactly a few hours.
10.) I guess last for right now. patience. You need it, and do everything right the FIRST time. Dont' go half *** to finish quicker or don't go half *** just because you don't want to spend the extra money. You'll pay in the long run.....
11.) Study, ask questions and know your **** before you get ready to fork out a ton of cash!!! You can never know too much....
Ill add more to this, I think I forgot some ****, but I hope this helps out some.
Old May 7, 2004 | 11:03 AM
HXMan's Avatar
Default Re: For the unexperienced turbo guy..... (patdemps)
yep
Old May 7, 2004 | 11:10 AM
roydogg's Avatar
Might as well add this too
https://honda-tech.com/zerothread?id=67146 -oil return
https://honda-tech.com/zerothread?id=109160 -oil return line setup
https://honda-tech.com/zerothread?id=114490 -oil return line parts
https://honda-tech.com/zerothread?id=71999 -where to weld oil return
https://honda-tech.com/zerothread?id=119100 -oil return line
https://honda-tech.com/zerothread?id=119539 -oil pan welding
https://honda-tech.com/zerothread?id=119715 -oil pan welding
https://honda-tech.com/zerothread?id=118687 -oil grade to use
https://honda-tech.com/zerothread?id=118694 -ft for oil feed line
https://honda-tech.com/zerothread?id=118807 -oil feed line
https://honda-tech.com/zerothread?id=119681 -oil feed line
https://honda-tech.com/zerothread?id=93550 -part for oil feed line
https://honda-tech.com/zerothread?id=114436 -where to buy brass t for feed line
https://honda-tech.com/zerothread?id=126335 -oil t question
https://honda-tech.com/zerothread?id=125438 -another place to buy oil lines
https://honda-tech.com/zerothread?id=131447 -oil feed line an/npt connector ?
https://honda-tech.com/zerothread?id=134078 -feed diagram
https://honda-tech.com/zerothread?id=133948 -oil bpst fitting again
https://honda-tech.com/zerothread?id=144586 -oil feed line restrictor
https://honda-tech.com/zerothread?id=155510 -oil leaks
https://honda-tech.com/zerothread?id=158018 -oil feed 3' better
https://honda-tech.com/zerothread?id=156571 -oil pan bolts
https://honda-tech.com/zerothread?id=170223 -oil pressure readings
https://honda-tech.com/zerothread?id=168084 -oil feed fitting
https://honda-tech.com/zerothread?id=131450 -oil feed diagram
https://honda-tech.com/zerothread?id=195068 -oil pressure
https://honda-tech.com/zerothread?id=122635 -drag 3 (to) coolant line?
https://honda-tech.com/zerothread?id=116891 -closed loop turbo info
https://honda-tech.com/zerothread?id=119724 -drag 3 turbo fitment (filing block)
https://honda-tech.com/zerothread?id=119690 -vacuum source
https://honda-tech.com/zerothread?id=94820 -closed loop
https://honda-tech.com/zerothread?id=120814 -Drag3 downpipe
https://honda-tech.com/zerothread?id=120867 -Drag3 + Tial connection
https://honda-tech.com/zerothread?id=118699 -wastegate vacuum line
https://honda-tech.com/zerothread?id=118767 -feul pump for drag 3
https://honda-tech.com/zerothread?id=121442 -fittings (brass T on block)
https://honda-tech.com/zerothread?id=123326 -blow off valve tightening
https://honda-tech.com/zerothread?id=123925 -catalytic converter removal o2 sensor
https://honda-tech.com/zerothread?id=124474 -'burning' in the turbo + blow off valve ?
https://honda-tech.com/zerothread?id=124580 -drag 3 manifold boost spike issues
https://honda-tech.com/zerothread?id=124662 -drag 3 tial fitment
https://honda-tech.com/zerothread?id=151845 -closed loop dump tube
https://honda-tech.com/zerothread?id=155616 -flexpipe issue
https://honda-tech.com/zerothread?id=159889 -blow off valve adjusting/cleaning
https://honda-tech.com/zerothread?id=163453 -egt probe tapping
https://honda-tech.com/zerothread?id=167329 -o2 sensor bung
https://honda-tech.com/zerothread?id=170498 -don't use tial gasket
https://honda-tech.com/zerothread?id=175270 -intercooler direction
https://honda-tech.com/zerothread?id=175277 -drag bolts suck
https://honda-tech.com/zerothread?id=206376 -bov greddy type s (loose)
https://honda-tech.com/zerothread?id=120548 -hondata install (solder stuff)
https://honda-tech.com/zerothread?id=98092 -hondata install heiarchy
https://honda-tech.com/zerothread?id=121859 -hondata info on pumps
https://honda-tech.com/zerothread?id=117300 -spark plugs
https://honda-tech.com/zerothread?id=156273 -spark plugs (2)
https://honda-tech.com/zerothread?id=116886 -changing plugs
https://honda-tech.com/zerothread?id=117326 -flexpipe for good price
https://honda-tech.com/zerothread?id=117733 -injectors, 440 or 550
https://honda-tech.com/zerothread?id=119569 -guage for autometer
https://honda-tech.com/zerothread?id=119591 -autometer guages
https://honda-tech.com/zerothread?id=121452 -aero fpr
https://honda-tech.com/zerothread?id=119884 -best FPR?
https://honda-tech.com/zerothread?id=118885 -place to buy aem fpr
https://honda-tech.com/zerothread?id=122590 -(installing) aeromotive fuel regulator
https://honda-tech.com/zerothread?id=86051 -removing/installing intank fuel pump
https://honda-tech.com/zerothread?id=120889 -profec b install
https://honda-tech.com/zerothread?id=116651 -Radiator fans
https://honda-tech.com/zerothread?id=119819 -diff between mechanical/electrical gauges
https://honda-tech.com/zerothread?id=117513 -turbo XS boost controllers and tial wastegates
https://honda-tech.com/zerothread?id=122396 -block guard
https://honda-tech.com/zerothread?id=107030 -rc 440 injector polarity
https://honda-tech.com/zerothread?id=82211 -rc 440 after hondata install
https://honda-tech.com/zerothread?id=121452 -aeromotive fpr part #
https://honda-tech.com/zerothread?id=125639 -hks ssbv clip
https://honda-tech.com/zerothread?id=153531 -more hks bov install
https://honda-tech.com/zerothread?id=125852 -carsound cat part #
https://honda-tech.com/zerothread?id=92570 -turbo timer relay
https://honda-tech.com/zerothread?id=128321 -turbo timer wiring
https://honda-tech.com/zerothread?id=132485 -radius rods
https://honda-tech.com/zerothread?id=63095 -rear seat removal
https://honda-tech.com/zerothread?id=133644 -injector fitment
https://honda-tech.com/zerothread?id=104940 -thermal to cat issues
https://honda-tech.com/zerothread?id=136680 -egt guage stuff
https://honda-tech.com/zerothread?id=137223 -which runner to tap for egt
https://honda-tech.com/zerothread?id=55987 -aem fpr against strut bar
https://honda-tech.com/zerothread?id=139706 -tools to carry
https://honda-tech.com/zerothread?id=140003 -base fuel map
https://honda-tech.com/zerothread?id=140774 -bleeding coolant
https://honda-tech.com/zerothread?id=156073 -js safeguard
https://honda-tech.com/zerothread?id=168470 -js safeguard, who is using
https://honda-tech.com/zerothread?id=160428 -summit part
https://honda-tech.com/zerothread?id=170160 -9psi, raise static fuel + retard timing
https://honda-tech.com/zerothread?id=170821 -wires to tap for guages
https://honda-tech.com/zerothread?id=171397 -c clamp pliers for hks bov
https://honda-tech.com/zerothread?id=171314 -EGT temps
https://honda-tech.com/zerothread?id=166449 -vacuum sources
https://honda-tech.com/zerothread?id=175335 -assembling an fittings
https://honda-tech.com/zerothread?id=176725 -oem fan clearance - move to right
https://honda-tech.com/zerothread?id=193263 -greddy profec b
https://honda-tech.com/zerothread?id=85987 -installing rc injectors
https://honda-tech.com/zerothread?id=106033 -matching wires rc injectors
https://honda-tech.com/zerothread?id=133644 -fitment of rc injectors
https://honda-tech.com/zerothread?id=107030 -polarity does not matter
https://honda-tech.com/zerothread?id=154935 -once installed
https://honda-tech.com/zerothread?id=159623 -tips to install
Old May 7, 2004 | 11:18 AM
Cruiser G's Avatar
Default Re: For the unexperienced turbo guy..... (roydogg)
holy jahoseph witness!
Old May 7, 2004 | 11:30 AM
macrosshn's Avatar
the son and the heir
Default Re: For the unexperienced turbo guy..... (Cruiser G)
WTF, don't tell me you searched for those threads off-hand.
Old May 7, 2004 | 11:33 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patdemps &raquo;</TD></TR><TR><TD CLASS="quote">6.) All fluids (oil, antifreeze, etc). Be prepared with some extra oil just incase you have to drain to get the shavings from drilling a hole in the oil pan. Buy the cheapest ****, drain that and fill with the good stuff (mobil 1 synthetic 10w30 is what i used). A new filter is great too. </TD></TR></TABLE>
Please tell me you took the oil pan off when you drilled the hole...
I took mine off, cleaned the inside out real well, laid a rag inside, then drilled, then removed the rag, wiped it out good again, then put it all back together.
Old May 7, 2004 | 11:40 AM
calib17a's Avatar
Here's another link that will definitely help you.
http://www.beesandgoats.com/bo....html
Old May 7, 2004 | 01:59 PM
Sketch_hs's Avatar
bookmarked
thanks!
Old May 7, 2004 | 04:50 PM
patdemps's Avatar
Default Re: For the unexperienced turbo guy..... (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">
I took mine off, cleaned the inside out real well, laid a rag inside, then drilled, then removed the rag, wiped it out good again, then put it all back together.</TD></TR></TABLE>
Ya, I definately took the oil pan off. I had to take it down the street to the auto garage to get welded.
This thread should get a sticky, instead of asking all the newb questions they could just look here.
Keep adding info everyone!
mrlegoman
Jan 15, 2008 09:20 AM
Boostage
Jan 25, 2004 06:48 AM
