no boost when wastegate hooked up
Old May 6, 2004 | 08:56 PM
91glassycrx's Avatar
Default no boost when wastegate hooked up
when i have the wastegate hookede up i get no boost only like 1or2 psi. but when i unhook the wastegate from the charge pipe it only boost to 5 psi
Old May 6, 2004 | 10:36 PM
Br1t1shguy's Avatar
Default Re: no boost when wastegate hooked up (91glassycrx)
which port you hooking it up to
Old May 7, 2004 | 05:38 AM
Default Re: no boost when wastegate hooked up (Br1t1shguy)
its hooked up to teh charge pipe right after the turbo
Old May 7, 2004 | 06:13 AM
MrCivic98's Avatar
in order to get vacuum, dont you have to hook it up to a port after the throtte body?
Old May 7, 2004 | 06:20 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: no boost when wastegate hooked up (MrCivic98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrCivic98 &raquo;</TD></TR><TR><TD CLASS="quote">in order to get vacuum, dont you have to hook it up to a port after the throtte body?</TD></TR></TABLE>
Gates are supposed to see boost, not vacuum.
Old May 7, 2004 | 06:29 AM
Default Re: no boost when wastegate hooked up (DaX)
well help me out guyz i'm going to the track tonight and i need this working right
Old May 7, 2004 | 06:31 AM
DaX's Avatar
DaX
Loved
Community Favorite
Check your intercooler piping for leaks. Never run without your boost source hooked to your wastegate. If you overboost...toast.
Old May 7, 2004 | 06:33 AM
Default Re: (DaX)
i have no leaks that I can find
Old May 7, 2004 | 07:28 AM
MiraiZ's Avatar
Default Re: (91glassycrx)
mines hooked up to my turbine ...you can use the intaake as well
Old May 7, 2004 | 07:35 AM
Default Re: (MiraiZ)
but it doesn't boost at all when the wastegate is hooked up
Old May 7, 2004 | 08:01 AM
MiraiZ's Avatar
-check your WG to see if its stuck open
-if its a tial, make sure that the little steel ring is in place (between the flange anf manifold
-check you vacuum lines for leaks
-check that you are hooking up your WG to a reliable boost source
Old May 7, 2004 | 08:08 AM
DaX's Avatar
DaX
Loved
Community Favorite
He's using an internally gated turbo fyi. My money is on a leak in the charge pipe.
pbzhb
Feb 19, 2008 11:50 AM
88crxhfb16
Aug 2, 2005 08:54 PM
StolenTeg
Aug 25, 2004 10:13 PM
FOrSfEd
May 17, 2004 10:13 PM
