Well JB Weld work on a manifold
Old May 7, 2004 | 06:24 AM
FOrSfEd's Avatar
Default Well JB Weld work on a manifold
Like a dumb *** a stripped out the thread in my manifold for my egts probe. So I wanted to use jb weld to secure it in the manifold but not sure since it gets so hot if it will hold up. This will be temporary unitl I have enough time to have it welded in.
Old May 7, 2004 | 06:25 AM
FwdCivicHatch's Avatar
Default Re: Well JB Weld work on a manifold (FOrSfEd)
if its temp, then go ahead. You could also just retap it too
Old May 7, 2004 | 06:32 AM
FOrSfEd's Avatar
Default Re: Well JB Weld work on a manifold (FwdCivicHatch)
Yeah I was thinking about that also. What kind of temps can jb weld handle?
Old May 7, 2004 | 06:41 AM
PM-Performance's Avatar
it wont hold. I tried it already. the ex gases get wayyyyy too hot . it just bubbles off.
Old May 7, 2004 | 06:50 AM
FOrSfEd's Avatar
Default Re: Well JB Weld work on a manifold (itr206)
Damn it. I guess I need to find a tap.
Thanks
Old May 7, 2004 | 06:54 AM
I just weld the bung in . when i tapped mine the damn threads ripped out. so i weld them in from then on
Old May 7, 2004 | 06:59 AM
FOrSfEd's Avatar
Yeah that sounds to be a lot better idea to do. I need to do this asap cause the exhaust leak from that little whole to rediculous
Thanks again
hondaeg8
May 12, 2006 12:30 PM
eg2phosizzle
Welding / Fabrication
11
Jan 24, 2006 09:37 AM
redboost10
Aug 31, 2004 11:55 PM
turboteg96
Mar 19, 2004 10:53 AM
