Wastegate Question?
Old May 9, 2004 | 04:45 PM
bottlefedintegra's Avatar
Default Wastegate Question?
I am in the final stages of putting the turbo system together in my car. I am running the turbo exh pipe out of the front of the car. I am thinking of running the wastegate dump tube into the turbo down pipe. Will this create any restrictions on exh flow or should they be kept seperate.
Old May 9, 2004 | 10:59 PM
RyanEJ8's Avatar
Default Re: Wastegate Question? (bottlefedintegra)
Cody at Lovefab is making mine with the dump-tube recirculated back into the downpipe. It shouldn't cause any restrictions.
Old May 10, 2004 | 03:06 AM
Default Re: Wastegate Question? (RyanCivic2000)
Thanks for the reply.
Old May 10, 2004 | 06:46 AM
jmagner's Avatar
It won't cause restrictions and it will help keep the noise down when the wastegate opens.
Old May 10, 2004 | 06:56 AM
Phantom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottlefedintegra &raquo;</TD></TR><TR><TD CLASS="quote">I am in the final stages of putting the turbo system together in my car. I am running the turbo exh pipe out of the front of the car. I am thinking of running the wastegate dump tube into the turbo down pipe. Will this create any restrictions on exh flow or should they be kept seperate. </TD></TR></TABLE>
Restrictions? It depends on what you mean. Closed loop exhaust is a tradeoff, you sacrifice power for quieter (hopefully) exhaust in boost.
Old May 10, 2004 | 07:14 AM
RyanEJ8's Avatar
Default Re: Wastegate Question? (Phantom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phantom &raquo;</TD></TR><TR><TD CLASS="quote">
Restrictions? It depends on what you mean. Closed loop exhaust is a tradeoff, you sacrifice power for quieter (hopefully) exhaust in boost.</TD></TR></TABLE>
Does it really sacrifice that much power?
Old May 10, 2004 | 07:19 AM
Phantom's Avatar
It depends on how the exhaust is made and a whole host of other variables. The only thing you can almost certainly count on is your peak hp will be lower with closed loop.
Old May 10, 2004 | 07:41 AM
Its a track only car so I am not really looking to keep the noise level down.
Old May 10, 2004 | 07:45 AM
DaX's Avatar
DaX
Loved
Community Favorite
Just make sure there is a very acute angle on entry of the dump into the downpipe. In other words, don't weld the dump entry into the downpipe perpendicular to the downpipe.
Old May 10, 2004 | 07:52 AM
RyanEJ8's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">Just make sure there is a very acute angle on entry of the dump into the downpipe. In other words, don't weld the dump entry into the downpipe perpendicular to the downpipe.</TD></TR></TABLE>
If it was perpendicular I could imagine it would blow the exhaust gases straight down to the bottom of the exhaust pipe kind of creating a "wall" that would block flow of the downpipe exhaust gases. Cody is making mine, I think he knows what he is doing.
turb0teg
Aug 25, 2010 08:56 PM
blwnengnls
Apr 12, 2007 06:40 PM
UK_prelude VTEC
Jan 20, 2006 08:19 AM
metal-x
Nov 8, 2002 07:14 AM
