TurboXS RFL Problem...
Old May 6, 2004 | 11:25 PM
civicshowracing65's Avatar
Default TurboXS RFL Problem...
hey guys i was wondering if you knew a way to solve my problem and if anyone had the same problem as me.
My turboxs rfl bov doesn't work. It did this before. It seems that the piston inside of the bov keeps getting stuck. Last time the piston was kinda wedged against the wall. I fiddled with it and it went back. Driving today it got stuck again and compressor surge at 10 psi doesn't sound good. Does anyone have a solution to this? What could I use to lube the piston?
Old May 7, 2004 | 11:04 AM
Default Re: TurboXS RFL Problem... (civicshowracing65)
anyone?
Old May 7, 2004 | 12:17 PM
USDM 4G VTEC's Avatar
how old is it?
take it to wherever u bought it
or called turboXS and ask them is a kit to be fixed is sold
Old May 7, 2004 | 12:19 PM
G
sh!t happens.
Default Re: TurboXS RFL Problem... (USDM 4G VTEC)
sounds like you need a new bov..but thats just my 2 cents
Old May 7, 2004 | 04:51 PM
Default Re: TurboXS RFL Problem... (G"UNIT)
good gawd i bought it brand new about 2 months ago. So sad bought a used greddy type s bov that had a good 30k miles on it and it is doing better. turboxs = good sound but shitty quality
Old May 7, 2004 | 05:13 PM
Ben Huynh's Avatar
Send it back under warranty. They'll repair or replace it. Either way it'll fix the problem.
Old May 7, 2004 | 11:48 PM
dragonhvu's Avatar
take the BOV apart... take the piston out of the cylinder... apply a thin layer of grease on the piston walls... make sure its evenly distributed... and reassymble. good as new... i do this to every TurboXS BOV i sell... and it works everytime
Old May 8, 2004 | 12:50 PM
Default Re: TurboXS RFL Problem... (dragonhvu)
could i use wd40? or what kind of greese should i use?
Old May 8, 2004 | 02:34 PM
project dc2's Avatar
dont use WD-40 not really a lubricant, it kidna washes it off after a lil while
hbyrd8701
Mar 25, 2009 06:54 AM
kenbo21
Sep 4, 2008 07:21 PM
oemDC2
Feb 26, 2004 08:03 PM
Aeka GSR
Jun 14, 2003 01:38 AM
brcivic411
Aug 11, 2001 10:49 AM
