oil pressure question
Old May 9, 2004 | 11:14 AM
reditr's Avatar
Default oil pressure question
Hi guys.. i am running a fully turboed built engine, with a stock oil pump . running 7 psi of boost. Can any body give me a clue on how much oil pressure should i have at full throttle?
Old May 9, 2004 | 01:31 PM
reditr's Avatar
Default Re: oil pressure question (reditr)
Any Help guys?
Old May 9, 2004 | 03:06 PM
99B16Si's Avatar
do a search...
ill help u out tho. an oil pump is belt driven so its rpm dependent, not throttle. mine never sees less than 20psi at idle weven when its hot as hell out side and compltely warmed up and it it stays around 80psi all the way till vtec then drops to about 70psi and holds right around there till redline
Old May 10, 2004 | 12:02 PM
reditr's Avatar
Default Re: (99B16Si)
Thanks a lot guy.
I appreciate a lot for your help
So my engine is working perfect as i have the same pressure as you have!
Old May 10, 2004 | 01:26 PM
USDM 4G VTEC's Avatar
Default Re: (reditr)
oil pump is crankshaft driven, not belt
is it RPM dependant
u shall see lil over 10 psi on idle and 50 psi at 3 k rpms
the oil pump shall bleed any oil pressure in excess of 75 psi
u might see more when cold...
but at WOT and going on VTEC, around 70 psi is about right
u shouldnt see less than 40 psi over 3k rpms or somethings is wrong
jarven093
11
Apr 30, 2007 07:00 PM
ham
Nov 23, 2005 06:06 PM
Soccerking3000
May 10, 2005 11:39 AM
smokey2.0
Apr 20, 2004 01:33 PM
gaskleppie
Sep 27, 2003 06:45 AM
