spring in wastegate Q
Old Mar 29, 2008 | 11:17 PM
SilverWarrior's Avatar
Default spring in wastegate Q
what does the spring in the wastegate do? what is the difference in lbs? And for a motor making 270-290 hp what size spring is necessary? ( tial wastegate)
Old Mar 29, 2008 | 11:32 PM
almostboostedgsr's Avatar
Default Re: spring in wastegate Q (SilverWarrior)
The spring regulates boost pressure. You can have a 7lb wastegate spring and it will stay at 7lbs. You only need a boost controller is you want to exceed the wastegate pressure.
Well the spring rates dont go according to horsepower. They go by psi. So for a motor making 270hp at the flywheel will need about 9-10psi of boost on a stock internal turbo honda. I belive a .4bar spring is 7psi. So you would need a boost controller to get it up to 10psi.
Old Mar 30, 2008 | 03:19 PM
Default Re: spring in wastegate Q (almostboostedgsr)
so I should get a .7lb if I want it to sit at .7psi? so for my setup .2 to .9 .7 is best?
Old Mar 30, 2008 | 03:32 PM
NJIN BUILDR's Avatar
List your whole set up.Engine,turbo,engine management,etc.....
pcguy760
Jul 8, 2011 09:08 AM
_Cyclone_
May 4, 2005 02:32 PM
B00ST2nR
Nov 3, 2004 11:39 AM
gdrum
Feb 24, 2004 01:55 PM
Turbo_Teg
Jan 14, 2002 07:35 PM
