Greddy Profec B Spec II help
Old Mar 29, 2008 | 02:16 AM
Outkast95LS's Avatar
Default Greddy Profec B Spec II help
Just got my car dyno tuned but I'm having some issues with my Greddy Profec B Spec 2 boost controler. I have the hi boost set to 16psi and on the dyno, boost would not stay consistent to redline. It kept fluctuating between 15 to 16 psi.. thus causing a wavey graph from 7000 rpm to 8700 rpm. My tuner told me to mess with the "gain" settings to get the boost to stay consistent. So my question is, without having to smash back and forth on the street, can anyone give me some tips as to what their settings are for their greddy profec b spec 2 boost controller?
I'm also having issues when I'm driving on the street at the "hi" setting. It starts to sputter/hit boost cut right around 5500. It didn't happen on the dyno, but only when driving on the street. Do you guys think it's the "gain" that needs to be adjusted as well? I checked the "peak boost" and it showed 17.4psi.. while my boost cut is set at 18psi via Crome. Any input/suggestions would be greatly appreciated. Btw, here's the dyno chart:
Old Mar 29, 2008 | 11:52 AM
JDM_Risa's Avatar
Default Re: Greddy Profec B Spec II help (Outkast95LS)
jon just throw a 15lb or desireable spring in there keep it simple
Old Mar 29, 2008 | 11:56 AM
Default Re: Greddy Profec B Spec II help (JDM_Risa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Risa &raquo;</TD></TR><TR><TD CLASS="quote">jon just throw a 15lb or desireable spring in there keep it simple </TD></TR></TABLE>
i know, i shoulda just did that instead!
Old Mar 30, 2008 | 02:03 AM
bump for some help!
Old Mar 30, 2008 | 12:06 PM
SOHC_MShue's Avatar
My profec did the same crap no matter what the gain setting. Boosting 17psi with high frequency fluctuations between 16 and 17psi. I now control boost through neptune instead
Old Mar 31, 2008 | 02:16 AM
Default Re: Greddy Profec B Spec II help (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">My profec did the same crap no matter what the gain setting. Boosting 17psi with high frequency fluctuations between 16 and 17psi. I now control boost through neptune instead </TD></TR></TABLE>
I think i got the settings right.. i gotta do some more pulls and see if i can get the gain to dial in so that i can get the spool to be a bit earlier
Old Mar 31, 2008 | 06:56 AM
IN VTEC's Avatar
When we had one, it would spike a psi higher than the target level and then do a slow decay as it climbed to the rev limiter.
Old Mar 31, 2008 | 11:13 PM
SOHC_MShue's Avatar
Default Re: Greddy Profec B Spec II help (IN VTEC)
often spikes can be fixed by lowering the set gain
Old Mar 31, 2008 | 11:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">often spikes can be fixed by lowering the set gain</TD></TR></TABLE>
Old Apr 1, 2008 | 01:39 PM
bump for some more user input
Old Apr 1, 2008 | 03:08 PM
SOHC_MShue's Avatar
switch to neptune and use pwm control
Old Apr 1, 2008 | 03:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">switch to neptune and use pwm control </TD></TR></TABLE>
that'll cost me more money in the end though
Old Apr 1, 2008 | 07:33 PM
SOHC_MShue's Avatar
I think its worth it...you get a lot more than just the boost control
Old Apr 1, 2008 | 07:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">I think its worth it...you get a lot more than just the boost control </TD></TR></TABLE>
true.. but i'll just stick with my crome pro and try to figure this boost controller out
Old Apr 1, 2008 | 09:57 PM
GodFather of Boost's Avatar
gain 15-20%
set gain 13lbs
Old Apr 1, 2008 | 09:59 PM
Default Re: Greddy Profec B Spec II help (GodFather of Boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GodFather of Boost &raquo;</TD></TR><TR><TD CLASS="quote">gain 15-20%
set gain 13lbs</TD></TR></TABLE>
more info on ur set up? is it comparable to mine?
Old Apr 2, 2008 | 07:45 PM
Its not my setup that is what i recomend you set it to. I use those units often.
Old Apr 2, 2008 | 07:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GodFather of Boost &raquo;</TD></TR><TR><TD CLASS="quote">Its not my setup that is what i recomend you set it to. I use those units often.</TD></TR></TABLE>
thanks.. i'll give it a shot and work from there.
Old Apr 2, 2008 | 09:12 PM
dpetro1's Avatar
i would listen to your tuner, he sounds like he is on the right track. what i suggest is that you adjust the SET GAIN to 0. Once you are getting the proper amount of boost (16psi) then start adjusting the GAIN until you get the consistency you desire. Only then should you play with the set gain to help with spool. Unfortunately making pulls to redline is probably the only way to do it.
also you "boost cut" issues may be through the controller itself. it has a built in warning and limit feature so make sure they are off if you want crome to handle boost cut.
Old Apr 3, 2008 | 01:50 AM
Default Re: Greddy Profec B Spec II help (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">i would listen to your tuner, he sounds like he is on the right track. what i suggest is that you adjust the SET GAIN to 0. Once you are getting the proper amount of boost (16psi) then start adjusting the GAIN until you get the consistency you desire. Only then should you play with the set gain to help with spool. Unfortunately making pulls to redline is probably the only way to do it.
also you "boost cut" issues may be through the controller itself. it has a built in warning and limit feature so make sure they are off if you want crome to handle boost cut. </TD></TR></TABLE>
thanks. i'll definitely try that. I had a friend who also suggested that the boost cut issue could be the controller itself. I need to take a look at it and make sure the settings on that is correct.
thepariah25
Jul 3, 2007 10:11 AM
hoskos
Jan 22, 2007 07:10 AM
brixity
Aug 27, 2004 07:44 PM
Andrew 825SM
Nov 4, 2002 09:50 PM
mod5
Sep 10, 2001 08:26 AM
