gm 3bar help
Old Mar 28, 2008 | 04:16 AM
boostedh22lude1's Avatar
Default gm 3bar help
i have a boosted 93 h22 with an s200, i have my 3 bar wired up but can i use manifold vacuum or does it have to go the ported throttle body vacuum, also how far back should my o2 sensor be from the turbo thanks for any help
Old Mar 28, 2008 | 05:47 AM
mike93eh2's Avatar
Default Re: gm 3bar help (boostedh22lude1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22lude1 &raquo;</TD></TR><TR><TD CLASS="quote">i have a boosted 93 h22 with an s200, i have my 3 bar wired up but can i use manifold vacuum or does it have to go the ported throttle body vacuum, also how far back should my o2 sensor be from the turbo thanks for any help</TD></TR></TABLE>
o2 sensor about 20-24" from turbo.
and any vacuum source will work for the map sensor. i.e. anywhere on the intake manifold.
Old Mar 28, 2008 | 06:13 AM
Default Re: gm 3bar help (mike93eh2)
i started it last night and it is running way rich and will hardly stay running, and it threw cel 41 as soon as i started it, the o2 is at the firewall were it is stock, dont know if thats to far? i had a base map set so i could break in the engine before tuning, it was burned for 880cc inj., and the gm 3bar i dont know if the map is the problem it just seems like it is running off a [freak]ed up map its has a bad hesistation at idle and doesnt want to rev
Old Mar 28, 2008 | 06:31 AM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22lude1 &raquo;</TD></TR><TR><TD CLASS="quote">i started it last night and it is running way rich and will hardly stay running, and it threw cel 41 as soon as i started it, the o2 is at the firewall were it is stock, dont know if thats to far? i had a base map set so i could break in the engine before tuning, it was burned for 880cc inj., and the gm 3bar i dont know if the map is the problem it just seems like it is running off a [freak]ed up map its has a bad hesistation at idle and doesnt want to rev</TD></TR></TABLE>
you said it right there. GET IT TUNED. a basemap is not gonna get your car running anywhere near perfect.
Old Mar 28, 2008 | 06:38 AM
i know its not going to run perfect i just need it running. i know its not going to idle very good with 880 without a tune but it doesnt run hardly at all
Old Mar 28, 2008 | 06:51 AM
mike93eh2's Avatar
so go get it tuned and then it will be running good..
Old Mar 28, 2008 | 06:55 AM
Default Re: (mike93eh2)
the engine has 0 miles on it i dont think its a good idea to tow it to a tuner and have them dyno a engine that has not even had the rings seated, the car should run with the basemap.
Old Mar 28, 2008 | 06:57 AM
mike93eh2's Avatar
my engine had 0 miles on it when i had it dyno tuned about a year and a half ago. it saw 8500rpms right from the get go. running better than ever still today. this is how most people do it.
there is no break-in on a engine. just go get it tuned.
Old Mar 28, 2008 | 07:03 AM
the rings must be seated before it can see high boost pressure, theres a reason there are basemaps, im not trying to get full power out of the engine it will not rev, it has a bad hesitation at ilde there is a problem somewhere so i cant have it tuned, any tuner will tell you make sure your car is in proper working order, fresh oil, plugs, no leaks, ect.
Old Mar 28, 2008 | 07:05 AM
any body with any help would be appreciated, im not trying to argue with any one about getting it tuned BUT IT HAS TO RUN FIRST thanks for any info
Old Mar 28, 2008 | 07:24 AM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22lude1 &raquo;</TD></TR><TR><TD CLASS="quote">any body with any help would be appreciated, im not trying to argue with any one about getting it tuned BUT IT HAS TO RUN FIRST thanks for any info</TD></TR></TABLE>
the tuner will obviously get it running
the rings take about 5 seconds to seat.
Old Mar 28, 2008 | 08:00 AM
94TegOwner's Avatar
just tow it to a tuner. the rings will seat very quickly while your tunning it, you dont need to break in the motor
Old Mar 28, 2008 | 08:04 AM
Running925's Avatar
motors 30 years ago used to take many miles b4 the rings were properly seated.
now days with newer materials, rings are seated within the first 5-10 minutes of running at an idle. Go get your car tuned.
19Accord97
Jan 24, 2010 05:54 AM
hondaman1212
Aug 2, 2008 06:33 PM
D15JDMARIO
Mar 3, 2007 07:39 PM
R_type
May 23, 2005 12:16 AM
fullraceacura
Mar 30, 2005 06:15 PM
