boost problem
Old Mar 29, 2008 | 09:39 PM
krazyhmongboi's Avatar
Default boost problem
just got my car running a few weeks back and never really took it all the way, but today while try'n it out..the boost would go to 8psi then cut out and go back to normal vacuum(-15ish) even when giving gas..what could be the problem?!
the wg is getting vacuum from a vacuum manifold, should it have its own source such as the fpr?..the bov goes off but im getting compressure surge at every let-go of trottle
thanks
Old Mar 29, 2008 | 10:03 PM
da_dude's Avatar
Is your car tune? And need more info of what you had done to your car and set-up you are running.
Old Mar 29, 2008 | 10:11 PM
its not tuned yet..just bought injectors, im running a fmu/missing link right now
t3/to4e turbo 70/.48
.6 bar tial
stock motor
just unconnected/connected the hoses coming off the vacuum manifold just incase and tested the car again and went to full boost and held it..wth!?
Old Mar 29, 2008 | 10:26 PM
almostboostedgsr's Avatar
Default Re: (krazyhmongboi)
If you have an external wastegate I would highly sugguest running a vac line from the wastegate to the vac inlet on the turbo. If there is no inlet on the turbo weld one on. This will pretty much fix your probelm.
Old Mar 29, 2008 | 10:38 PM
hmm makes sense i'll try and get that done..thanks!
Old Mar 29, 2008 | 10:46 PM
No probelm.
Old Mar 30, 2008 | 12:28 AM
da_dude's Avatar
Default Re: boost problem (krazyhmongboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazyhmongboi &raquo;</TD></TR><TR><TD CLASS="quote">the boost would go to 8psi then cut out and go back to normal vacuum(-15ish) even when giving gas..</TD></TR></TABLE>
I'm guessing that cut out you are having is because you're not getting enough fuel. Are you still on stock injectors? And that 15ish at vacuum, is that WOT or part throttle? What kind of BOV do you have?
Old Mar 30, 2008 | 12:31 AM
yea right now im still running stock injectors till i get the 550's in and save up for a tune job,
its partial trottle..i builds to 8 psi then just shoots right back down, car feels dead too..then when i back off the trottle and give it more gas it'll spool up again
Old Mar 30, 2008 | 12:43 AM
Yeah, I didnt know you had stock injectors. That's the probelm right there. Its not getting enough fuel to build enough boost.
Old Mar 30, 2008 | 12:44 AM
da_dude's Avatar
Does it shoot back down by itself when you are still WOT or did you left off? Whenever you are not on the gas pedal or little to no load it will be in vacuum depending how much load you are putting on the throttle. But don't go boosting your car with stock injectors or else you'll blow it up pretty quick. Wait for your injectors to arrive, install them, get some sort of engine management, and get it tune.
hmm i guess tuning will come sooner then i thought..thanks alot for the great info guys
would dsm 550cc's require a resistor box?
xlasianizelx
Aug 19, 2009 09:15 PM
1fastlude1
May 2, 2008 01:40 PM
B16CRXT
Apr 24, 2005 07:50 PM
AlphaMike
Apr 8, 2004 12:37 PM
ATS*Mark
Mar 18, 2004 06:54 AM
