d16 injector question dsm or s2000 for boost?
Old Mar 27, 2008 | 02:27 AM
140sx's Avatar
Default d16 injector question dsm or s2000 for boost?
Hi im going to be boosting a friend of mines car (d16 non vtec) and i have a set of factory s2000 f20c injectors from my build. or should i buy the dsm injectors??
This is just a simple turbo kit im peiceing together for a reliable dd.
I beleive the s2000 factory injector size is 370cc and the dsm stuff is 440cc, do i need to run a resistor box for the s2000? how about the dsm?
Thanks in advance.
Old Mar 27, 2008 | 06:21 AM
ys1civicsi's Avatar
Default Re: d16 injector question dsm or s2000 for boost? (140sx)
it all depends on what dsm injectors you run if you run the blue tops then yes you will need the resister box due to them being peak hold i believe instead of high resistance haha i may have got them backwards. Anyway the s200 injectors should be fine if you are running low boost i would save the buck and throw in the s2000 juicers and call it a day.
Quickridez_3
Aug 18, 2007 01:22 PM
s2kkk
Dec 9, 2005 04:08 PM
shadowdawn
Jun 23, 2002 04:14 AM
