Turbo LS Tuning
Old Mar 25, 2008 | 04:58 PM
90Rexx's Avatar
Default Turbo LS Tuning
Ive got a turbo LS that i havnt started yet. Its obd0 and i have a chipped ECU from an uberdata sort of thing. I plan on using an apexi afc neo with it to fine tune my fuel. is an afc compatable with obd0?
Old Mar 25, 2008 | 05:43 PM
Schister66's Avatar
Man U FTW
The easiest way is to convert to OBD1 and run Crome....its cheap and works
Old Mar 25, 2008 | 06:16 PM
mtber's Avatar
Default Re: (Schister66)
1. You will need the proper injectors/fuel/map sensor pump for your setup.
2. You will need an engine management solution such as a chipped obd1 ecu on hondata, crome, ectune, neptune etc.
Read over http://www.phearable.net/tech/....html it explains most of what you need to know.
jfoster
Apr 12, 2011 04:42 PM
jonathanh
Engine Management and Tuning
Aug 11, 2010 12:29 PM
blasterman87
Sep 26, 2009 04:29 PM
90lsvcrxva
Feb 15, 2007 11:33 AM
4door93civic
Feb 24, 2006 08:30 PM
