Universal question??
Old Mar 20, 2008 | 01:46 PM
D17alltheway's Avatar
Default Universal question??
What is the significance of shaft play in a turbo? in other words why do people emphasize "zero shaft play"?
Old Mar 20, 2008 | 02:01 PM
Schister66's Avatar
Man U FTW
The shaft play is an indication of the bearing condition in the turbo. If there is normal shaft play, the turbo will function properly. If there is too much shaft play, there is excessive gap in the bearing to the shaft which will result in the compressor and turbine wheels moving laterally more than they're supposed to. This results in oil passing by the compressor and into the charge piping. In bad cases, the compressor wheel can contact the housing and start chewing off parts of the aluminum housing.
Bictorious
Aug 31, 2004 08:26 PM
j-specB20sol
May 11, 2004 10:41 PM
5STAR3
Jul 15, 2003 09:53 AM
bigTom
Oct 10, 2001 09:07 AM
