boost pressure and flow rates
Old Mar 24, 2008 | 09:38 AM
solman95's Avatar
Default boost pressure and flow rates
i am new to boosting if i run a smaller t25 turbo at 5 psi and compare it to a gt35r at 5 psi being that the two turbos are way diff in size but but have the same amount of boost pressure the gt 35r should flow a volume of more air so my question is can i run a t25 at persay 10 psi and match the volume of air that the gt35r is putting out
i ask this because i have a 95 del-sol with a stock d16z6 and just purchased a t25 my friends are telling 8 psi max boost i was just curious if its not so much how many psi but ho wmuch volume of air you are cramming into the cylinders that will pop the motor
sm00thk0zz
Jul 20, 2006 06:47 AM
StolenTeg
Apr 15, 2006 09:46 PM
VaporTrail
Oct 20, 2003 05:46 PM
Yosshaa
Oct 8, 2003 03:54 PM
DXRacer
Feb 21, 2003 07:04 AM
