TURBONETICS DELTAGATE MARKII WASTEGATE need help
1 Post
i have this wastegate, and in the middle of the wasgate it has a fitting says boost, that goes into the compressor side, top fitting says vacuum does that get hooked uo to the intake mani side or compressor as well? thanks alot for any help guys....also the car is a 95 civic hatch gsr engine,t3/t4 turbo,skunk2 mani..
Mr. Badwrench
Re: TURBONETICS DELTAGATE MARKII WASTEGATE need help (miguel329)
the middle fitting goes to the compressor. this will run only wastegate spring boost pressure.
the other is for a boost controler.
hondaguyexsi
08-10-2005 12:00 PM
