Never enough wont start after swap posts
Old Mar 27, 2008 | 09:23 AM
turbahatch's Avatar
Default Never enough wont start after swap posts
Ok to start out i have air/fuel, spark, and compression. I recently pulled a running 2000 ls b18b went through the whole thing with oem Honda bearings, seals and gasket's. Eagle rods and srp 9.5 pistons consistent compression across all cylinders. stage 2 crower cams with stock cam gears. And for management I'm running a chipped p06 with uber turbo map walbro 255hp and evo 560cc injectors running at 55 psi fuel pressure.
Ok now i just got done putting it back in and i cant get it to fire or stumble or even pop timing lines up firing order is correct, all grounds are good and no cel's.
Im stumped can someone point me in the right direction???
Old Mar 27, 2008 | 09:46 AM
DA_HONDA_BOY's Avatar
Default Re: Never enough wont start after swap posts (turbahatch)
try your stock fuel injectors
is your base map setup for 560 injectors
Old Mar 27, 2008 | 09:48 AM
turbahatch's Avatar
Default Re: Never enough wont start after swap posts (DA_HONDA_BOY)
ya it is programmed for the 560 injectors but i am planning to try the old injectors thanks for the feedback
rice a roni
Engine Management and Tuning
Apr 26, 2026 03:22 PM
Nick M
Aug 1, 2012 09:07 AM
Davidls
Jun 18, 2010 01:23 PM
1990_integra_DA9
Jun 13, 2008 09:22 PM
B16CRXT
Nov 18, 2007 03:18 PM
