loss of torque with light flywheel?
Old Mar 28, 2008 | 04:50 PM
86crxintheworks's Avatar
Default loss of torque with light flywheel?
im about to order a clutch and flywheel for my build and i have ben reading up on what other people have experienced and i came across someone saying that ull loose torque with a light flywheel on a boosted setup...thoughts and opinions???? ill be running around 350 to 400 hp on a ls vtec turbo setup.fully built.will a lightweight flywheel make me loose torque???
Old Mar 28, 2008 | 04:51 PM
nfn15037's Avatar
Default Re: loss of torque with light flywheel? (86crxintheworks)
Reducing rotating mass will not make you lose torque.
Old Mar 28, 2008 | 04:58 PM
Default Re: loss of torque with light flywheel? (nfn15037)
thanks for the reply.thats wat i was leaning toward...anymore thoughts or opinions anyone?
Old Mar 28, 2008 | 05:00 PM
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">Reducing rotating mass will not make you lose torque.</TD></TR></TABLE>
x2
Old Mar 28, 2008 | 06:00 PM
mike93eh2's Avatar
you dont want a lightweight flywheel on a boosted engine.
Old Mar 28, 2008 | 06:21 PM
00-501itrspec's Avatar
Default Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">you dont want a lightweight flywheel on a boosted engine.</TD></TR></TABLE>
OK , and hes asking WHY , or will it reduce torque .
Old Mar 28, 2008 | 06:26 PM
nfn15037's Avatar
Care to explain?
Old Mar 28, 2008 | 06:28 PM
street_accord94's Avatar
Default Re: (nfn15037)
Care to explain?</TD></TR></TABLE>
I'd like to know as well.
Old Mar 28, 2008 | 06:44 PM
Legion's Avatar
* B A N N E D *
Default Re: (street_accord94)
The lighter the better. It doesn't make you fall out of boost, you just have to shift faster. The only time a light flywheel is bad is if you run out of revs trying to launch on large slicks. This happens because your engine doesn't hold enough momentum to launch without bogging. But if that happens, I'd say running smaller slicks would be the better solution since a heavier flywheel robs power and torque across the entire RPM range. People also seem to ignore the fact that their ginormous aftermarket rods add a ton of weight to the rotating assembly.
Having said that, I'm running an 8lb flywheel. Had the same flywheel on 2 engines, 3 setups (N/A, JRSC, turbo), and wouldn't have it any other way.
BTW, this topic has been beaten to death a million times in the archives.
Modified by Legion at 7:53 PM 3/28/2008
Old Mar 28, 2008 | 06:46 PM
mike93eh2's Avatar
Default Re: (Legion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legion &raquo;</TD></TR><TR><TD CLASS="quote">The lighter the better. It doesn't make you fall out of boost, you just have to shift faster.
8lbs here. Had the same flywheel on 2 engines, 3 setups (N/A, JRSC, turbo), and wouldn't have it any other way.</TD></TR></TABLE>
and what do you gain with it on a turbo'd engine?
dont forget about drivability..
Old Mar 28, 2008 | 06:58 PM
Legion's Avatar
* B A N N E D *
dont forget about drivability..</TD></TR></TABLE>
You mean other than more power and faster acceleration? What more could you want!
"Driveability" isn't an issue. Give yourself a week or two to adjust to it and you'll never know you even have a light flywheel. Although it does kind of suck when you borrow a friend's car for a few days, then go back to your own car and start stalling out because you forgot how to drive it...
Old Mar 28, 2008 | 09:07 PM
TorganFM.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legion &raquo;</TD></TR><TR><TD CLASS="quote">The lighter the better. It doesn't make you fall out of boost, you just have to shift faster. The only time a light flywheel is bad is if you run out of revs trying to launch on large slicks. This happens because your engine doesn't hold enough momentum to launch without bogging. But if that happens, I'd say running smaller slicks would be the better solution since a heavier flywheel robs power and torque across the entire RPM range. People also seem to ignore the fact that their ginormous aftermarket rods add a ton of weight to the rotating assembly.
Modified by Legion at 7:53 PM 3/28/2008</TD></TR></TABLE>
Good real world scenario explanation.
Old Mar 29, 2008 | 07:35 AM
Westrock2000's Avatar
Default Re: (TorganFM.)
The lighter flywheel will have less momentum when you shift into gears causing the engine to feel like its stumbeling a little more. Poeple may interpret this as a loss of torque, when it is in reality the engines willingness to change RPM's quicker (coming to down to meet a transmission at a lower speed, like 0 MPH).
Old Mar 29, 2008 | 07:58 AM
b16a4's Avatar
Default Re: (Westrock2000)
i used to drop out of boost using a 7.5lbs flywheel
i went back to stock.
Old Mar 29, 2008 | 08:30 AM
quicksilver1689's Avatar
i ♥ snails
yeah ive noticed some lighthweight flywheel applications to cause trouble launching turning it into a bog or broil situation.
Old Mar 29, 2008 | 08:35 AM
gringotegra's Avatar
Default Re: (quicksilver1689)
i just changed from a 7.5lb flywheel back to my OEM gsr flywheel. Im pushing about 320whp and i sware it feels alot sower! i didnt think launching was that hard with the lighter flywheel. Maybe it is just me but it doesnt feel the same...
Old Mar 29, 2008 | 08:41 AM
zex_cool's Avatar
my engine came with a light flywheel. no idea what weight but i hate it. its a bitch to drive and you have to shift as if you were racing jst not to have the car studder. when i get the motor out ill be going back to a stock flywheel.
Old Mar 29, 2008 | 08:47 AM
mike93eh2's Avatar
stock FTW!
i guess some people just dont realize a lightweight flywheel isnt worth it on a boosted honda. just turn the boost up a 1/4 psi if you want the extra power of a lightweight flywheel lol.
Old Mar 29, 2008 | 09:08 AM
b16a4's Avatar
yes, with a light flywheel, you have to shift like if your racing.
imho, light flywheels are for NA
Old Mar 29, 2008 | 09:25 AM
llslick's Avatar
Default Re: (b16a4)
I agree lighter is better just balance all your internals with it
Old Mar 29, 2008 | 10:17 AM
2point2's Avatar
Default Re: (llslick)
A light flywheel works for me. I'm a little concerned about harmonics but ignorance is bliss.
Old Mar 29, 2008 | 10:45 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (2point2)
lightweight flywheel here
had no problems with it when i switched from oem , unless you dont know how to drive then you will get used to it very quickly...
also to whoever said to just turn up the boost... that works in some situations but i would rather have a more efficient engine to begin with and run less boost
Old Mar 29, 2008 | 11:10 AM
mike93eh2's Avatar
Default Re: (EARLdaSQUIRREL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL &raquo;</TD></TR><TR><TD CLASS="quote">lightweight flywheel here
also to whoever said to just turn up the boost... that works in some situations but i would rather have a more efficient engine to begin with and run less boost </TD></TR></TABLE>
even if its just a 1/4 of a psi ? lol
Old Mar 29, 2008 | 11:21 AM
FarinaMotorsports's Avatar
I was thinking the same thing. One trip around the block was all I needed to adjust. And when I'm driving on the street I don't shift fast like I would on the track, I shift slow and smooth and I've had no issues. I haven't found any reasons to go back to the OEM flywheel.
Old Mar 29, 2008 | 12:00 PM
Civicman86's Avatar
Sorry to continue to the offtopic but a lightened fly was one of my favorite mods to my car.
