turbo problems
Old Mar 28, 2008 | 11:42 AM
KAsEN05's Avatar
Default turbo problems
95 eg hatch with ls/vtec turbo but my turbo wont boost and if it does build any it just cuts out. help!!
here's the build..
engine:
ls/vtec
JE 9:1 84 mm piston
eagle rods
golden eagle sleeve
supertech tit retainer
supertech duel valve springs
stage 5 port job
aem adjustable camgear
new vtec oil pump
Turbo:
garrett 62 mm turbo
tial 38 mm wastegate
turbo xs bov
turbo xs duel stage boost controller
ram style turbo maifold
neptune ecu
clutch master lighten flywheel
zoom stage 3 clutch
880 cc injectors
255 walbro fuel pump
Old Mar 28, 2008 | 11:58 AM
95jeremie's Avatar
Default Re: turbo problems (KAsEN05)
check all your couplers
you have a boost leak
build a pressure tester out of pvc to test the system
Old Mar 28, 2008 | 02:43 PM
KAsEN05's Avatar
Default Re: turbo problems (95jeremie)
thanks ill try it and report back
KAsEN05
Jul 14, 2008 05:37 PM
CaptainMorgan
Mar 9, 2007 05:34 PM
CaptainMorgan
Motorcycles
15
Feb 24, 2007 09:11 AM
CaptainMorgan
Jan 30, 2007 07:36 PM
