b18c1 boost
Old Mar 23, 2008 | 01:34 PM
peck1005's Avatar
Default b18c1 boost
how much boost and HP can i get out of a GSR motor without any prabloms. the motor right now WITHOUT turbo has 245 HP. i just got a turbo kit (450cc inj. 2.5 bar map sensor) and need to know what is the most boost i can run with. the motor has a little work done to it but stock cams i think it was bored to 2.0L. when i know how much boost i can run i will know what ECU tuner i will get.
Old Mar 23, 2008 | 01:43 PM
Schister66's Avatar
Man U FTW
I dont even know where to begin with this thread....the comments should prove to be rather amusing.
Old Mar 23, 2008 | 01:48 PM
BlownHatch's Avatar
Default Re: (Schister66)
245 hp all motor damn thats pretty sick
i would say no more then 48.999949 psi
on a serious note we need more info
Old Mar 23, 2008 | 01:52 PM
dannydos's Avatar
Default Re: (BlownHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peck1005 &raquo;</TD></TR><TR><TD CLASS="quote">how much boost and HP can i get out of a GSR motor without any prabloms. the motor right now WITHOUT turbo has 245 HP. i just got a turbo kit (450cc inj. 2.5 bar map sensor) and need to know what is the most boost i can run with. the motor has a little work done to it but stock cams i think it was bored to 2.0L. when i know how much boost i can run i will know what ECU tuner i will get. </TD></TR></TABLE>
Old Mar 23, 2008 | 02:02 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">I dont even know where to begin with this thread....the comments should prove to be rather amusing. </TD></TR></TABLE>
I hope he's not near a gas tank when the flaming begins...
Old Mar 23, 2008 | 02:07 PM
cjordan's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
I hope he's not near a gas tank when the flaming begins...</TD></TR></TABLE>
LMAO!!!!
Old Mar 23, 2008 | 02:19 PM
Schister66's Avatar
Man U FTW
lol...as corny as that may be Mac, i literally laughed out loud when i read this
Old Mar 23, 2008 | 03:21 PM
peck1005's Avatar
i am keeping up with G35 and 350Z and i out ran an integra type-R with 3 ppl in my car and only him in his car. if i wasn't in iraq i would show you my dyno results. with my N/A motor i'm running 245 HP at 8,200 rpms at about 189 lbs torq i think thats what the dyno test was. i have been in iraq over a year now so i don't exactly remember what my last test was.
Old Mar 23, 2008 | 03:32 PM
BlownHatch's Avatar
Default Re: (peck1005)
o i did't relize you were keeping up with 350s,if thats the case i would say you r closer to 350 whp
because you are fighting for my freedom i will tell you be carefull with what you ask on here because if you ask a silly q you will get a silly a.so with no more info then you gave us i would say dont go over 9 psi untill you are a little more familiar
with boost
Old Mar 23, 2008 | 04:05 PM
gt35rSI's Avatar
first off ( 450 inj and 2.5 map sensor ) does not = turbo kit and
secondly no Gsr with a 2.0 bore is making 245 hp on stock cams.
So not to be an *** you have a lot to learn. A motor can handle 5lbs on a small turbo or 20lbs on a tiny turbo making the same power. So if what you meant was HP people make 500 on stock blocks w/ some head work or 350 on a stock motor all day on 91 gas.
Old Mar 23, 2008 | 05:01 PM
peck1005's Avatar
Default Re: (gt35rSI)
just to clear some thing up on my motor, short history on motor: my brother was here in iraq 2 years ago and when he got home he got the b18c1 motor i now own. he payed 3,500 on the motor and gsr trany i think one of his buddys got it from japan. then he spent another 2,800 on engine work 2.0 bore and what ever else he had done i really can't tell you guys what exactly was done to the motor i havent talked to my bro in like 1 1/2 years b/c he is stationed in germany and i am here in iraq. i got the motor 6 days befor i had to leav for iraq so i didn't have time to find much out about it. i did find a dyno graph in the car with 245 hp at i think 8200 rpms with like 189 lbs of torq (the graph may or maynot have been for his/my car i don't really know). my bro put the motor in a 95 honda civic hb with a stage 3 clutch. i bought the car from him at a really low price b/c he didn't need it in germany. i payed only 3,700 for the car. i know when he was racing it he was keeping up with stock 350s and g35s (350 and g35 may have been faster but not by much) and when i had it i outran a type-r with 3 ppl in my car. thats that.... i now have a t3/t4 turbo kit a samall intercoller (i'm going to spray nitrous into) i have a garett t3/t4 kit with the 450cc inj. and 2.5 map sensor. with the 2.0 bore i don't know what safe boost i can run. i'm not trying to BS about this i just want to know some things i really have never got into this untill now
Old Mar 23, 2008 | 05:27 PM
gringotegra's Avatar
ummm 245whp in a 1995 hatch keeping up with 350Z's and G35's..... if you had 245whp you would be way ahead of those 14 sec cars...id put the car at more like 160-170whp...but who really knows.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peck1005 &raquo;</TD></TR><TR><TD CLASS="quote">i now have a t3/t4 turbo kit a samall intercoller (i'm going to spray nitrous into) i have a garett t3/t4 kit with the 450cc inj. and 2.5 map sensor. with the 2.0 bore i don't know what safe boost i can run. i'm not trying to BS about this i just want to know some things i really have never got into this untill now</TD></TR></TABLE>
well we need more info than that...from what it looks like you have about 30% of the kit if that...id do some more research before you post....ive got a stock GSR and im at 318whp@10psi with a T3/T04E 57trim... still has alot of room to go...the limmit really depends on your tunner...if you have a shitty tunner it may not even hit 300whp...who knows...
Old Mar 23, 2008 | 05:28 PM
dbiker207's Avatar
if that motor made 245 then your gonna need to put new pistons in it that are lower compression
Old Mar 23, 2008 | 05:36 PM
blackcherry's Avatar
Default Re: (dbiker207)
finally someone noticed this! any na car with that much power def does not have pistons for a turbo
Old Mar 23, 2008 | 08:13 PM
Schister66's Avatar
Man U FTW
My finger is getting the twitchy feeling when its near the lock icon.....best watch out
Old Mar 23, 2008 | 08:27 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">My finger is getting the twitchy feeling when its near the lock icon.....best watch out </TD></TR></TABLE>
Use the FORCE, LUKE..
Old Mar 23, 2008 | 08:38 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peck1005 &raquo;</TD></TR><TR><TD CLASS="quote"> right now WITHOUT turbo has 245 HP... the motor has a little work done to it but stock cams i think it was bored to 2.0L. </TD></TR></TABLE>
im sorry i just cant believe that... unless thats an engine dyno your talking about, and thats still damn near impossible... and ive stock 95 hatches with stock GSR engines with ihe with 3 people in the car keep up with a 350z.
anyhow, post up a full parts list of what the motor currently has, and we can better advise you. we really need to know the compression ratio.
Old Mar 23, 2008 | 10:22 PM
count me out's Avatar
* B A N N E D *
lol.
your brother hasnt talked to YOU in over a year, because he lied to you and your gsr is making 180 crank horsepower.
Old Mar 23, 2008 | 11:48 PM
gt35rSI's Avatar
Default Re: (count me out)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by count me out &raquo;</TD></TR><TR><TD CLASS="quote">lol.
your brother hasnt talked to YOU in over a year, because he lied to you and your gsr is making 180 crank horsepower.</TD></TR></TABLE>
x2
Old Mar 24, 2008 | 11:09 AM
LastGenEK's Avatar
Haha I read that some one in japan made a 2.6l K24 na fully built with honda and made 265hp
Its hard to believe that a gsr is making 245hp
Old Mar 24, 2008 | 09:45 PM
* B A N N E D *
Default Re: (LastGenEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LastGenEK &raquo;</TD></TR><TR><TD CLASS="quote">Haha I read that some one in japan made a 2.6l K24 na fully built with honda and made 265hp
Its hard to believe that a gsr is making 245hp </TD></TR></TABLE>
well then they did something wrong because a fully built k20 hybrid should be in the 300's na.
Old Mar 24, 2008 | 11:22 PM
95 civic turbo_gsr's Avatar
if you really have 245whp gsr motor in a civic you should be eating 350z's and g35's. also you said your motor is a b18c1 and that your brother got it in japan. i'm kinda confused cause i thought a c1 motor is a usdm and a b18C is a jdm. hhmm
Old Mar 25, 2008 | 10:04 AM
peck1005's Avatar
Default Re: (95 civic turbo_gsr)
after reading everything i started doing some resurch on my car and engine and dyno graph found in car. this is what i got, i had my wife look in the car for any kind of paperwork done on the car she found an invoice with a name and number. when i called the number it was a friend of my brothers who did the work on the car. he didn't remember all the name brands of thing put in the engine but he did remember doing the work. he charged my bro $2800 on a 2.0 bore, low compression pistons, port and polished head, valves, stock cams, pulleys and stage 3 clutch and a set of tires including all labor. he said the car was set up for boost. he also said the exhaust was hollowed out from the header back. he could not remember the exact compression ratio but he said it was lower then a stock GSR. although never put on a dyno he did say the <U>MOTOR</U> should have about 195/200 HP na. i asked him about the dyno graph i found and he told me it sounded like the turboed but stock integra LS b18b that was always up their with my bro. he is the one who put the turbo on the LS at the same time he did my bros car. i then got a hold of the owner of the turboed integra LS and he said that was his dyno sheet he must have left it in my bros car.
Old Mar 25, 2008 | 10:18 AM
T3T495GSR's Avatar
Well, that clears up any confusion now
Old Mar 25, 2008 | 10:20 AM
T3T495GSR's Avatar
Well, that clears up any confusion now huh
