p75 w/ s200 hondata on b16a turbo?
p75 w/ s200 hondata on b16a turbo? my question is . is it going to work? i got it on ebay the s200 with p75 all installed and i just got my b16a turboed.. its running good up to 5500rpm and than nothing.. maybe i just need some tuning coz its too reach or not enough fuel but maybe the ECU p75 is not good with my vtec or my engine?
Re: p75 w/ s200 hondata on b16a turbo? (boostedflaredb16si)
so can i some how add a vtec with hondata or should i use my p28 ECU and move the s200 from the p75 to p28, by the way will i need any extra parts if i have to move the hondata from the p75 to the p28? thanks a lot
Re: p75 w/ s200 hondata on b16a turbo? (UNIKATUT)
You can have the vtec circuit added to the non-vtec ecu.You need to have the car tuned period.Your tuner can add the vtec circuit to the ecu for you.
Re: p75 w/ s200 hondata on b16a turbo? (mtber)
thanks a lot guys, One of the things is. that i am my tuner im going to tune it my self with a help a of a friend who is a good tunner but of different product not hondata, he never tuned hodnata before. I am in east Europe so there is not professional hondata tuners here.. people dont even know what hodnata is so thats why i am asking for your help. I have the p30 ECU so i can use it, i mean i can transfer all the chips from the p75 with the hondata all to the p30 because i have the know sensor on my JDM b16A 2nd gen 170hp. So i would just like to know the easiest way to go .. p30 or keep my p75/s200 and just add the Vtec option. Here is a pic of both ECU if anybody can look at it and tell me what i need to move from one to another i would be very thankful!
Re: (rudebwoy)
this is the conversion you need http://www.xenocron.com/catalo....html
make sure you specify what board you have. http://www.xenocron.com/instal...r.htm
Re: (dbiker207)
thanks guys, i cant jsut buy hondata s300 gotta save some money.. and i will use my p30ECU and jsut move hondatas200 to the p30 i guess this will be the easiest way to go.All i have to do now is wind out what components i have to solder or unsolder in the p30 so that the s200 will work.. any help with that?
Re: (mtber)
its romediton v4 the latest version i download it from hondata site and the hondatalogger to, i was wondering .. so i need any other software of hardware to program some calibrations to my eCu or to make some changes ? or can i do it all with romeditor4?
Re: (mtber)
Romeditor 4 does not have the alternate vtec output option. That is only on an s300.
Original poster: You have not purchased Romeditor 4, so you must purchase that, then you need a emulator and chip burner. The cost of these is more than the cost of upgrading to the s300. You will aslo save yourself a huge hassle with tuning the s300.
S300
S200, emulator and and datalogging
S300
Re: (Spunkster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster »</TD></TR><TR><TD CLASS="quote">Romeditor 4 does not have the alternate vtec output option. That is only on an s300.
S300
Hmm, Last time I spoke to Doug he told me that it was going to be implemented, maybe I miss-understood.
I agree with upgrading to s300
S300
Re: (mtber)
ok i went to the store and got srial calbe that came with drivers but the romeditor 4 is still not working, asking for serial number? is it possible that romeditor4 works only with hondata usb/serial cable? I did install the hondata on my p30 ECU so i have Vtec and everything, i got chip burner, eprom, and emulator .I have boost and stage 3 on my s200 .if cable thing doesn't work i guess i can just edit maps with romeditor and save them as a file and just record the file on my eprom. is that going to work?
P>S if i download romeditor3 is it free or it still need hondata cable?
Re: (UNIKATUT)
If I remember right their is a "thingy" in the Hondata cable for romediter 4 similar in function to the blue box.Adding the vtec components to your ecu is the most economical solution.
Re: (building boost)
Ok the s300 is out of option , i guess i will use the s200 to datalog and Crome to tune my maps, than i will make my own .bin/.ct2 with crome and burn it to the Eprom and driveee...
Silverbullet114
Engine Management and Tuning
06-25-2008 11:29 AM
