Catch Can Set-Up
Old Mar 24, 2008 | 05:27 PM
StolenTeg's Avatar
Default Catch Can Set-Up
Im unsure of which catch can set-up to run, some people run it with a few fitting off the valve cover while some go to the two 14mm allen key plug on the back of the block.
It would make sense that going with the two fitting on the back of the block would be the best?
Old Mar 24, 2008 | 05:34 PM
xenocron's Avatar
Default Re: Catch Can Set-Up (StolenTeg)
Do a search for a thread created by 'Dasher' on here...lots of good testing and explanation. You should be able to create your own determinations from reading that.
I myself like the Endyn or Z10 breather setups as they are a complete kit.
On my own car I am running on of the block breather fittings and the stock upper port from the back of the valve cover to the breather tank. Taking some pressure off both the upper and lower cavities.
Old Mar 25, 2008 | 04:43 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Catch Can Set-Up (xenocron)
https://honda-tech.com/zerothread?id=697498
https://honda-tech.com/zerothread?id=1674798
for what its worth, i used the endyn with no pukes at 500whp.
now, i need the t1 setup.
slowassBubble
Jul 25, 2012 06:30 PM
TravisBiggie
Jun 23, 2012 07:40 PM
jtm509
May 30, 2010 11:19 AM
negusjuda
Apr 10, 2010 09:54 AM
Shadowz7429
Jan 4, 2010 10:32 AM
