Looking 4 A Semi-Buit DD..
Old Mar 28, 2008 | 03:40 PM
Kurly's Avatar
Default Looking 4 A Semi-Buit DD..
Just Curious What Kind of Numbers Can I Expect 2 See On A OBD2 GSR, Stock Internals & A Carb Legal Bolt Turbo Kit? Tuned 2 Around 8-10 PSI. Keep In Mind I Say Carb Legal Cuz Im From Cali..
And I Dont Have The $ 4 A Full-Built 20 PSI Street Sniper... Yet
Thanx In Advance H-T!!!!
Old Mar 28, 2008 | 04:09 PM
TunerN00b's Avatar
Default Re: Looking 4 A Semi-Buit DD.. (Kurly)
Is There A Reason That The First Letter Of Every Word Is Capitalized?
Which turbo kit? That makes much more difference than what pressure you intend to run it at.
Old Mar 28, 2008 | 09:39 PM
HiProfile's Avatar
Default Re: Looking 4 A Semi-Buit DD.. (TunerN00b)
If you get the intercooler as well as the kit (assuming you're thinking Greddy), you could expect between 200-250whp, depending on your other parts.
Your best option is to get ITR cams and the exhaust, since those can be installed and still make it legal yet give you the best bang for the buck with the turbo.
BTW the search button does work fantasticly for n00bs such as yourself. I found this in 3 seconds:
https://honda-tech.com/zerothread?id=1862455
Nicks95GSR
Oct 4, 2007 02:24 AM
gq420j
May 16, 2007 11:14 AM
KrAzYdc2
Mar 22, 2007 07:39 PM
Baron55
Nov 27, 2005 12:44 PM
INTEGLS96
Feb 18, 2004 12:55 PM
