what rods should i to go with crower or eagle???
im doing a low compression build on a gsr block and a built b16 head, trying to get 400hp. im using arias 9 to 1 pistons and i have both crower I beam rods and eagle H beams, im not too sure which ones to go with??? can i get some opions. thanks
Modified by hondakid94 at 9:07 PM 3/23/2008
Re: what rods should i to go with crower or eagle??? (hondakid94)
if you have both then i would use the crowers they are a better rod. that said both would work fine, as long as the eagles have the newer larger bolts
Re: what rods should i to go with crower or eagle??? (dbiker207)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dbiker207 »</TD></TR><TR><TD CLASS="quote">if you have both then i would use the crowers they are a better rod. that said both would work fine, as long as the eagles have the newer larger bolts</TD></TR></TABLE>
you sure crower I beams are stronger than eagle H beams? dont they advertise that as a mild boost mainly NA rod?
Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">
you sure crower I beams are stronger than eagle H beams? dont they advertise that as a mild boost mainly NA rod?</TD></TR></TABLE>
http://www.crower.com/cat/impo...shtml
if they are the 4340 billet rods they can handle all the power he can throw at it.
if they are the maxi light rods they are not as strong.
Re: (dbiker207)
if they are the maxi light rods they are not as strong.</TD></TR></TABLE>
oh snaps, i was only aware of the maxi light version, good info
Re: (dbiker207)
thanks for the good info. the 4340 Steel Billet Connecting Rods are the same ones i have, so it loooks like i should go with the crower rods over the eagle's since i already have them.
Re: (blackeg)
for 400 hp eagles will be fine. but i guarantee you're gonna want more power at some point so you might as well spend the extra $200 and get the better ones, crower.
Re: (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 »</TD></TR><TR><TD CLASS="quote">for 400 hp eagles will be fine. but i guarantee you're gonna want more power at some point so you might as well spend the extra $200 and get the better ones, crower.</TD></TR></TABLE> Extra 200? I've been quoted $280 for Eagles and yet I see the Crower Rods MSRP 726! Where do you get the Crower Rods for 500?
i ♥ snails
i think this is kinda going the wrong way, hes looking for 400whp, eagles will handle that no problem, he can save a few hundred bucks to spend on another aspect of the build, not saying anything bad about the crowers there quality pieces but for this specific application almost any aftermarket rod will do.
Both rods will handle 400 hp. It´s not hp that kills rods it is rpm. So if you are reving to like 9000 eagles would be fine. If you wants to rev higher.. I would trust the crower billet ones better.
So if you are gonna rev to like 9000 and make 400 hp I would chuse the lightest rod.
Re: (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote"> Extra 200? I've been quoted $280 for Eagles and yet I see the Crower Rods MSRP 726! Where do you get the Crower Rods for 500?</TD></TR></TABLE>
damn i didn't realize eagles were so cheap. i also didn't realize crowers were so expensive... DAMN! i got my crowers back in the day for like $600.
Re: (Mikey3000)
damn i didn't realize eagles were so cheap. i also didn't realize crowers were so expensive... DAMN! i got my crowers back in the day for like $600.</TD></TR></TABLE>
prices go up....yay economy haha
