Passing Emissions in NJ
Old Mar 19, 2008 | 05:13 PM
slooogsr's Avatar
Default Passing Emissions in NJ
Whelp, I am not sure if i will be able to procure a new inspection sticker due to more strict regulations in NJ. Has anyone had any luck passing emissions in nj on a mild turbo setup? Any ideas on what to do in order to get it to pass?
Old Mar 19, 2008 | 09:44 PM
esedulerp5tenin's Avatar
Default Re: Passing Emissions in NJ (slooogsr)
i didn't even attempt to do state inspection when i was turbo'd, i just knew a shop that would pass me for like $70.
Old Mar 19, 2008 | 10:15 PM
nowtype's Avatar
As long as you have a catalytic converter and pass the basic inspection, you will pass. I've had my car through a few times, and every time I get really nervous and every time they tell me flat out, they don't care. Inspections done in Rahway, NJ and Edison, NJ.
Old Mar 20, 2008 | 02:14 AM
slooogsr's Avatar
Default Re: (nowtype)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esedulerp5tenin &raquo;</TD></TR><TR><TD CLASS="quote">i didn't even attempt to do state inspection when i was turbo'd, i just knew a shop that would pass me for like $70.</TD></TR></TABLE>
I am hoping I will find a shop still willing to do so in south jersey.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype &raquo;</TD></TR><TR><TD CLASS="quote">As long as you have a catalytic converter and pass the basic inspection, you will pass. I've had my car through a few times, and every time I get really nervous and every time they tell me flat out, they don't care. Inspections done in Rahway, NJ and Edison, NJ.</TD></TR></TABLE>
This will be the last resort for sure. I really don't see how they will not even consider the emissions test.........
Old Mar 20, 2008 | 02:54 AM
tekturbo's Avatar
I just buy a sticker from a shop,this is my fifth car and I have never even been to an inspection. lol
Old Mar 20, 2008 | 02:45 PM
nowtype's Avatar
Default Re: (slooogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slooogsr &raquo;</TD></TR><TR><TD CLASS="quote">
I've done it 3 times. 1st time passed immediately. 2nd time failed due to high NOx I believe. Fixed the fuel mixtures and passed the 3rd time. The only thing they commented on was how stiff my clutch was.
1994 Acura Integra LS with a HMT turbo setup.
Old Mar 20, 2008 | 03:08 PM
slooogsr's Avatar
1994 Acura Integra LS with a HMT turbo setup.</TD></TR></TABLE>
Hmmm, this is interesting........
I know it is more difficult to get a sticker when you try to pass and end up failing. I will roll the dice and try to find a shop to buy one and if not then I will try my luck through th e DMV.....
Old Mar 20, 2008 | 03:18 PM
nowtype's Avatar
I know it is more difficult to get a sticker when you try to pass and end up failing. I will roll the dice and try to find a shop to buy one and if not then I will try my luck through th e DMV.....</TD></TR></TABLE>
You've only heard wrong things. If you fail, go back in 30 days I believe, they only test you for the thing(s) you failed for. That is of course if you don't have any blatant issues like non working lights.
This isn't CA where they tow your car if you have it modified. Not to mention, they aren't police. The worst they can do is fail you. Then you can go pay $150 for a sticker.
Old Mar 20, 2008 | 03:56 PM
slooogsr's Avatar
This isn't CA where they tow your car if you have it modified. Not to mention, they aren't police. The worst they can do is fail you. Then you can go pay $150 for a sticker.</TD></TR></TABLE>
They always bitch about that when you come to them (shops) with a failed sticker..... more work for them?
Old Mar 20, 2008 | 06:53 PM
Adriano's Avatar
On 96+ cars, they plug in a scanner and check for codes. If you dont have a stock ecu, you are not going to pass.
Adriano
Old Mar 20, 2008 | 06:59 PM
slooogsr's Avatar
Default Re: (Adriano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano &raquo;</TD></TR><TR><TD CLASS="quote">On 96+ cars, they plug in a scanner and check for codes. If you dont have a stock ecu, you are not going to pass.
Adriano</TD></TR></TABLE>
OBD1...... see sig
Old Mar 21, 2008 | 08:58 AM
v8 integra's Avatar
i feel your pain..im in north jersey and my 96 ex with a obd1 ecu is due for inspection in a few months and im worried because i dont know of any shops around here that would pass it
Old Mar 21, 2008 | 06:56 PM
slooogsr's Avatar
Default Re: (v8 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8 integra &raquo;</TD></TR><TR><TD CLASS="quote">i feel your pain..im in north jersey and my 96 ex with a obd1 ecu is due for inspection in a few months and im worried because i dont know of any shops around here that would pass it</TD></TR></TABLE>
Let me know how you make out.........
Old Mar 21, 2008 | 07:26 PM
awdgsx96's Avatar
I was there when my friend's 2G GSX passed, and did it with flying colors. 6 bolt with pistons, rods, 2G head, bigger turbo, FMIC, 3'' turbo back with a magnaflow cat. This was at the Mt. Holly inspection DMV.
Old Mar 22, 2008 | 07:52 AM
Default Re: (awdgsx96)
damn, i guess i'll try my luck w/ state inspection once i get boosted again @ edison. this is awesome news
Old Mar 22, 2008 | 08:23 AM
slooogsr's Avatar
Default Re: (esedulerp5tenin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esedulerp5tenin &raquo;</TD></TR><TR><TD CLASS="quote">damn, i guess i'll try my luck w/ state inspection once i get boosted again @ edison. this is awesome news </TD></TR></TABLE>
Yea I am still a bit hesitant. I know my tuner (Chris at Xenocron) said it would be very tough passing emissions with my setup without some fine tuning to say the least. I have a conservative tune on the rich side but I am not certain what range the car sees on the rollers at the dmv.
Old Mar 22, 2008 | 04:11 PM
awdgsx96's Avatar
Some people have gotten away with saying their car was too low and they didn't want to damage the bumper and they didn't bother with the rollers.
Old Mar 22, 2008 | 04:15 PM
slooogsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdgsx96 &raquo;</TD></TR><TR><TD CLASS="quote">Some people have gotten away with saying their car was too low and they didn't want to damage the bumper and they didn't bother with the rollers. </TD></TR></TABLE>
Would that mean they would only check emissions during idle?
Im out driving it tonight, hopefully no cop pulls me over........
Old Mar 22, 2008 | 04:17 PM
nowtype's Avatar
This whole thing is retarded. If your fuel mixtures are off, the fail you. Big deal, you look at what it says and you add or remove fuel as needed and go back and retest. Not a big deal.
Old Mar 22, 2008 | 06:12 PM
awdgsx96's Avatar
Im out driving it tonight, hopefully no cop pulls me over........ </TD></TR></TABLE>
Rather than putting it on the rollers, I think they have you put it in neutral and bring the RPMs up to like 1700 and than 2300 or something like that.
Old Mar 22, 2008 | 09:36 PM
slooogsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype &raquo;</TD></TR><TR><TD CLASS="quote">This whole thing is retarded. If your fuel mixtures are off, the fail you. Big deal, you look at what it says and you add or remove fuel as needed and go back and retest. Not a big deal.</TD></TR></TABLE>
Thanx for your input asshat...... My tuner is over 2 hours away and I am not capable of adding or removing fuel since I don't know how to tune or have the software to do so. Please go back to lurking unless you have something that has substance to add to the thread......
Old Mar 22, 2008 | 09:38 PM
slooogsr's Avatar
Mods please lock or delete this thread....... I have all the info I need.
SIguy626
16
Jul 19, 2006 01:59 PM
smelldaOdaa
Mar 25, 2006 04:24 PM
plusONE jboy
11
Nov 25, 2004 10:09 AM
boostincoupe
Jul 8, 2003 02:28 AM
