B16a to Ls question
Old Apr 8, 2008 | 12:59 PM
Panda Eg6's Avatar
Default B16a to Ls question
Hey h-t. I have a jdm b16a right now boosted and tuned on 10lbs. I need to sell the b16 and want to put a Ls motor in. The only problem I am comming across is the ECU. What am I going to have to do about that? Is it possible to run my chipped and tuned p28 for the time being till I get the car re-tuned for the ls or what? Thanks lol.
Old Apr 8, 2008 | 03:26 PM
katoeh2o's Avatar
Default Re: B16a to Ls question (Panda Eg6)
You can have your ecu chipped by moetes.net to run crome. Then down load LS bin and you are good to go.
Old Apr 8, 2008 | 07:35 PM
Panda Eg6's Avatar
Default Re: B16a to Ls question (katoeh2o)
Can you explain this a little more? I will check it out, but kinda confused. Thanks
Old Apr 9, 2008 | 02:02 AM
katoeh2o's Avatar
http://www.moates.net/
Sorry I ment theses guys can chip your ecu
Old Apr 9, 2008 | 07:54 AM
Panda Eg6's Avatar
Default Re: (katoeh2o)
So what you are saying is to just get a new chip and download some kind of Ls turbo base map?
Old Apr 9, 2008 | 10:15 AM
delslo93's Avatar
Default Re: (Panda Eg6)
You can run your chipped P28 but you will want at least a base map for your setup until you can get it fully tuned. Hit up any tuner around (I perfer J-K-Tuning.com) and tell them your setup and they can burn you a new chip with a basemap that you can use for the time being until you get it tuned. Then all you will need to do is pop out your old chip and replace it with the new one.
Old Apr 9, 2008 | 06:40 PM
Panda Eg6's Avatar
Default Re: (delslo93)
ok bro thanks for the help
Old Apr 9, 2008 | 06:45 PM
Panda Eg6's Avatar
The site was very helpful. The custom chip will be perfect to drive around on till fully tuned!
evosix
Engine Management and Tuning
Aug 26, 2016 04:37 AM
JDMstatus95
Mar 2, 2007 10:24 PM
Snail Tuning
Oct 5, 2004 04:18 PM
blackeg
Jul 15, 2004 09:46 PM
