oil on pison?
Old Apr 2, 2008 | 04:15 AM
1fastlude1's Avatar
Default oil on pison?
so ive finished my build, mahle pistons, eagle rods, micro. crank,balanced,hondata s200, i started it last night and it started fine then mises pulled a plug and can see oil on the piston, compresoin is180 across all 4, wtf? head gasket? please help
Old Apr 2, 2008 | 04:36 AM
siblues's Avatar
Default Re: oil on pison? (1fastlude1)
I am having the same problem with my built and sleeved motor except on the two pistons with the oil the compression is slightly higher.We are leaning towards the valve seals leaking.I was also told it could be due to rings but that answer was also said to have bad coompression too?
Old Apr 2, 2008 | 04:43 AM
1fastlude1's Avatar
Default Re: oil on pison? (siblues)
im pretty sure my valve seals are ok i had the head on the motor before i built it
Old Apr 2, 2008 | 04:45 AM
siblues's Avatar
Well then I would do a leak down and see what you come up with.I also had a head on my motor that was working fine but i changes the springs and retainers in mine and then the problem started.When does it smoke under load or at idle?It is smoking right?
Old Apr 2, 2008 | 05:00 AM
siblues's Avatar
Have you noticed any oil in the coolant too sorry I forgot to ask in the previous post.I coudnt find any in mine either but I could here a slight sound of air leaking between cylinders when doing the compression test which made my tuner think it was in the head somewhere.
Old Apr 2, 2008 | 05:09 AM
1fastlude1's Avatar
thats whast weird it does not smoke,and i didnt notice any oil but i will look again when i get home,thanks for the info so far.
Old Apr 2, 2008 | 05:27 AM
siblues's Avatar
Any time man just trying to help it was frustrating for me too.
Old Apr 2, 2008 | 05:37 AM
1fastlude1's Avatar
ya its driving me crazy ive spent 6 months now building this thing and i dont want to rip it apart
AllMotorMark
Apr 23, 2020 08:30 PM
jdmcivicferio
Jan 13, 2008 06:41 PM
the.hamburglar
Jun 20, 2006 09:34 PM
siis2fast
Mar 25, 2006 12:42 PM
Screaminz28
Oct 16, 2002 11:35 AM
