10:1 compression ratio
Old Apr 7, 2008 | 06:40 PM
LERRY's Avatar
Default 10:1 compression ratio
i'm probably going to use 10:1 pistons (brother has a set he will give to me for free!) in my 85mm GE Sleeved LS/V turbo build and would like some feedback and possibly dyno graphs for those of you who are running 10:1 c/r. thanks!
Old Apr 7, 2008 | 06:46 PM
b16bri's Avatar
Default Re: 10:1 compression ratio (LERRY)
That compression ratio is kinda on the high side. What psi are you trying to run ?
Old Apr 7, 2008 | 06:55 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
10:1 gsr with ls crank... 81.5mm stock sleeves 20psi Sc61
Old Apr 8, 2008 | 04:54 AM
TheShodan's Avatar
Moderator
Default Re: (tannerLSt)
Are you kidding, I LOVE that compression!!! When tuned correctly, it can be a BLAST, on and off-boost. Less boost needed to make the same power.
Old Apr 8, 2008 | 05:33 AM
93supercoupe's Avatar
Default Re: (TheShodan)
REMBER THAT MOST VTEC ENGINES ARE HIGHER THAN THAT, ID BE MORE WORRIED ABOUT THE 85MM SLEEVES, BUT THEY WILL BE FINE ASLONG AS UR NOT WAY HIGH ON POWER.
Old Apr 8, 2008 | 05:41 AM
Schister66's Avatar
Man U FTW
I wouldn't be too worried about it. Many people are starting to use higher compression ratios especially for the street. True, you can run as much boost, but you dont need to run as much to make the same amount of power. With sufficient fuel and the right octane rating, you can make a good amount of power and still have good off-boost.
Old Apr 8, 2008 | 06:51 AM
ham's Avatar
ham
A year ago i made 472whp with 10:1 arias pistons in a 81.5mm gsr block with stock sleeves, ls crank, SC61 20psi and 93 octane. Motor is still in great condition too.
Old Apr 8, 2008 | 06:52 AM
Rage Cayman's Avatar
Default Re: (Schister66)
Tuning is the name of the game .
Old Apr 8, 2008 | 08:24 AM
LERRY's Avatar
thanks for the replies! did some more research and i'm for sure going to use the 10:1 pistons for my setup!
Old Apr 8, 2008 | 08:28 AM
tegdude227's Avatar
good link check it out
http://forums.evans-tuning.com...=4931
95civhb
Jan 4, 2010 01:49 PM
Rooftop voter
Nov 2, 2008 10:01 AM
slowcrx954
Nov 23, 2006 07:49 AM
Soon_2b_evil
Nov 16, 2003 07:41 PM
s0liDyNe
Jul 19, 2003 10:24 PM
