low oil pressure
Old Apr 8, 2008 | 05:51 PM
NIGHTRIDER27's Avatar
Default low oil pressure
i installed a B&M oil cooler and filter relocator on my turbo d series, the oil pressure is low, I've got 5.5qts in it how many quarts of oil are you using? or maybe air bubble? thanks
Old Apr 8, 2008 | 05:53 PM
blwn95civic's Avatar
Default Re: low oil pressure (NIGHTRIDER27)
oil coolers have a tendency to lower oil pressure... How much oil pressure did u have before and what do u have now?
Old Apr 8, 2008 | 05:57 PM
iam at only like 10-15 on start up i haven't let it run for to long since that seems kinda low , before id see like maybe 60 i think on start up if i remember right
Old Apr 8, 2008 | 06:15 PM
wow, that is way too low on cold start up, what size oil lines were used?
Old Apr 8, 2008 | 06:27 PM
i believe the line is 1 in diameter hose but the inside diameter is smaller than 1 in. i think there is about 80 inches of line total but with all that hose to connect everything. but with the bigger oil filter that is used ,the cooler, hose, and oil in the turbo dose 5.5 qrts of oil sound like a sufficient amount? or with all that line am i just going to lose to much pressure and going to have to shorten the run?
Old Apr 8, 2008 | 06:31 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NIGHTRIDER27 &raquo;</TD></TR><TR><TD CLASS="quote"> i installed a B&M oil cooler and filter relocator on my turbo d series, the oil pressure is low, I've got 5.5qts in it how many quarts of oil are you using? or maybe air bubble? thanks </TD></TR></TABLE>
Nothing but problems with that thing from B&M. I too dropped a ton of oil pressure on one of my road race cars with that thing. Wasn't worth it from that company. Honda motors don't really like the relocation. I lost several bearings from that kit. Please get rid of it, and get something else.
Old Apr 8, 2008 | 06:33 PM
5.5 sounds like it should be more than enough, the best thing to do is pull the plug wires off and turn the motor over long enough to pick up oil and fill the lines, then check the oil on the dip stick as soon as you can and see where its at to let you know how much is in the pan while the motor is holding oil in the lines and head. But you do need to shorten all the lines up as much as possible.
Old Apr 9, 2008 | 06:26 AM
Default Re: low oil pressure (blwn95civic)
thanks for the insight guys. iam going to go over the damn thing again this weekend once i get home. if anyone else has any other idea please let me know, am glad to hear them out, i got to get this damn car moving again. -Jake
Old Apr 9, 2008 | 06:51 PM
DLO01's Avatar
Do people here know about putting spacers or washers in the oil pressure relief valve? It effectivly increases tension on the spring and makes it open later to more pressure. You need to take off the sump to access it. I have 2 washers in mine and its back up to normal pressure.
I have done it to my ITR as I also have a cooler installed.
xkrazyxjbrkerx75
Aug 9, 2011 02:47 PM
ALL IMPORT
Jul 23, 2006 02:43 PM
_gurusan_
Dec 20, 2005 10:41 AM
screen_name
Apr 23, 2005 07:22 AM
wade
Oct 10, 2004 07:38 PM
