Quick Resistor Box Question
Old Apr 10, 2008 | 07:25 AM
rdssk8rcs1's Avatar
Default Quick Resistor Box Question
Does it matter if when you are installing a resistor box in a vehicle that didnt come with one taht you hook up the 12v wire to all 4 of the wires that you cut going to the ecu? Or can you just hook it up to any switched 12v?
Just wondering if it mattered and if anyone knows why it would/ would not?
Thank you in advanced
Old Apr 10, 2008 | 07:51 AM
LA_HONDAS's Avatar
Default Re: Quick Resistor Box Question (rdssk8rcs1)
yel-blk or red-blk wires from the injectors go to the resistor box and the red wire on the resistor box go to a 12v under dash fuse box not to the batt...
Old Apr 10, 2008 | 08:03 AM
totsie7944's Avatar
Huh? All you do to wire in a resistor box is splice into the "Dead" plug on the right side of the engine bay. You need a digital volt and Ohm reader ($20 from radio shack) and you just touch all the tabs and find the 4 that go to the injectors, and splice into them with the resistor 4 wires..
Old Apr 10, 2008 | 08:46 AM
rdssk8rcs1's Avatar
Default Re: Quick Resistor Box Question (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">Huh? All you do to wire in a resistor box is splice into the "Dead" plug on the right side of the engine bay. You need a digital volt and Ohm reader ($20 from radio shack) and you just touch all the tabs and find the 4 that go to the injectors, and splice into them with the resistor 4 wires..</TD></TR></TABLE>
Yeah i know about those 4 i was wondering about the 12 volt wire that is coming from the resistor box. The 4 splice into the 4 from the injectors I was just wondering about the 5th
Old Apr 10, 2008 | 08:52 AM
totsie7944's Avatar
O the 5th wire just splices into the 4 wires going back into the dead plug....so you will have all 4 of those wires soldered together and the 1 wire from the resistor spliced with them.
https://honda-tech.com/zerothread?id=1263795
Step #8
mpf90
Mar 23, 2009 11:54 AM
vladd
Aug 4, 2006 04:28 PM
fast[R]
Jun 11, 2004 03:19 PM
Prelude Racer
Mar 8, 2004 10:10 PM
bruthaboost
Dec 17, 2001 09:08 PM
